Lineo5 Duo
$799.00
Adding to cart… The item has been added
Dual-Output linear Power Supply for Volumio electronics and compatible with all 5V audio gear. Both outputs deliver 5V/4A of clean power thanks to the low-noise design with audio grade components, elevating the performance of your system. Supports 110V AC and 230V AC input voltages (50/60Hz).
The Lineo5 Duo IS compatible with the following:
Volumio Rivo, Volumio Rivo Plus, Volumio Preciso, Volumio Primo V2, Volumio Primo V3 , Volumio Primo Plus
The Lineo5 Duo is NOT compatible with the following:
Volumio Integro, Volumio Motivo
Made in Florence Made in Florence
Free Delivery Free Delivery
30 Day Returns 30 Day Returns
Performance and Convenience
The Dual-Output design makes Lineo 5 Duo the perfect choice to streamline and simplify your system while maximizing audio quality. A single PSU with two independent outputs that allows to feed two electronics, such as Rivo Plus and Preciso, ensuring they both run on high-quality power to enjoy the finest details and transients in your music.
Linear Power Supply
Lineo 5 Duo is the Linear Power Supply dedicated to your electronics, replacing the external switching PSU. Upgrading your system with a linear PSU will provide you with a large reservoir of clean and stable power while minimizing electrical noise, resulting in more engaging realism, transients and details.
Sounds Good
Built with premium audio-grade components, Lineo 5 Duo is engineered to reduce ripple and interference for clearer audio and lower noise. The low ESR caps provide a large reservoir of power ready to be delivered to your system when needed the most. The chassis made entirely of aluminum integrates heatsinks to provide efficient cooling and stability.
Dual Output
The Lineo 5 Duo can power two electronics at the same time. It's the best way to improve your system so you can enjoy the highest audio quality your electronics can deliver. All while minimizing boxes and cables, making for a convenient and discrete upgrade even in compact systems.
Double the Outputs, All the Power
5V / 4A per Output
Lineo 5 Duo delivers 5V and 4A on each output, a perfect complement to our electronics. Each output is completely independent, with dedicated regulators and filtering. The 5V output ensures compatibility with a vast range of audio gear, making it extremely versatile in all sorts of systems.
Aluminum Chassis
We choose aluminum whenever possible as it provide us with a high-quality, robust and non-magnetic material that will last you a lifetime. The tank-like construction highlights simplicity while leveraging the integrated heatsink to manage thermal dissipation, passively cooling the electronic components.
Toroidal Transformer
The toroidal transformer is the beating heart of the Lineo 5 Duo - a standalone configuration that powers the PSU. This transformer is not just designed to deliver the required power to each independent output, it's well supersized to graciously handle even the most challenging of listening sessions without ever coming even close to its limits.
Included in the box
Volumio Lineo 5 Duo
Output power cords (2)
Input power cord (EU, US, UK, AU/NZ)
Hardware Specifications
INPUT VOLTAGE: 110V-120V / 60Hz (AC) | 220V-240V / 50Hz (AC)
OUTPUT VOLTAGE: 2× 5 V (DC)
OUTPUT CURRENT: 2× 4 A (max)
POWER CONSUMPTION: 120 W (max)
TRANSFORMER TYPE: Toroidal
DESIGN: Dual linear regulation
PROTECTIONS: Easy to access fuse
FILTERING: Reduced ripple and interference
CAPACITORS: Audio grade low ESR caps
BULK CAPACITANCE: 40000uF
RESIDUAL NOISE: 20uV
CONNECTORS: GX-16 (2 pins)
OUTPUT POWER CORD: GX-16 (2 pins) to barrel jack (5.5x2.1mm)
OUTPUT POLARITY: Tip positive
Design
CHASSIS: Aluminum
FINISH: Black
DIMENSIONS: 27 × 22.7 × 7.7 (H) cm
WEIGHT: 4.75 Kg
User Manual
Access the Volumio Lineo 5 Duo User Manual below:
Reviews
