The highlights
- Bit-perfect playbackFrom a version of Volumio OS tuned for Rivo Ultra.
- Ultra-low noise and low-jitterFemto-clock with 54 fs RMS phase noise on the integrated outputs. Temperature-compensated clock (TCXO) on the USB DAC output.
- Large selection of digital outputsSeven outputs: USB, I2S/DSD over HDMI, AES/EBU, two S/PDIF coaxial (one on a BNC connector, one on RCA) and two S/PDIF optical.
- Linear power supplyTwo independent linear regulation stages, fed by an audiophile-grade toroidal transformer.
- Storage expansion slot for SSDsUp to 16 TB for your music library.
- Ultra-wide touchscreen display12 inches on the front, plus a display in the knob.
- Advanced and customizable UIVolumio OS inside, Volumio Premium built in. Works with TIDAL, Qobuz, Spotify Connect, AirPlay and Roon Ready.
Rivo Ultra is our flagship streamer, powered by a version of Volumio OS optimized to match its design.
Made in Florence
Designed, assembled and tested by hand, in Italy
Rivo Ultra is designed in Florence, Italy, where every unit is assembled and tested by hand. One team operating under the same roof, designing and crafting both hardware and software. Each unit is thoroughly tested and carefully packaged before we send it your way.
More about Volumio in FlorenceLook inside
The most refined streamer we’ve ever created.
Rivo Ultra represents the ultimate digital transport, the perfect synergy of audio-grade hardware and software design. It’s the evolution of the very best technology we developed, elevated to new audiophile heights.
Outputs
5 ways to your DAC
Rivo Ultra is a digital transport. It sends the signal to your DAC through USB, I2S/DSD over HDMI, AES/EBU, S/PDIF coaxial or S/PDIF optical. A 12 V trigger switches your other components on and off.
USB DAC
1536kHz
Up to PCM 1536 kHz / 32-bit and DSD1024 (or DSD256 when multiroom audio is enabled). The USB DAC output features power filtering and signal-integrity reconstruction. Supports volume control adjustments from Rivo Ultra with compatible DACs.
I2S/DSD over HDMI
768kHz
Up to PCM 768 kHz / 32-bit and DSD1024 (or DSD256 when multiroom audio is enabled). The pinout routing of the HDMI connector is adjustable to match Rivo Ultra with your DAC.
AES/EBU
192kHz
Up to PCM 192 kHz / 24-bit and DSD64 (DoP), providing you with a balanced digital output.
S/PDIF coaxial
192kHz
Up to PCM 192 kHz / 24-bit and DSD64 (DoP), over RCA and BNC connectors for maximum flexibility.
S/PDIF optical
192kHz
Up to PCM 192 kHz / 24-bit and DSD64 (DoP), with 2 outputs over TOSLINK connectors.
Connections
From your network to your DAC
Stream over Gigabit Ethernet or dual-band Wi-Fi, or play from the internal SSD and USB drives. On the back, I2S/DSD and video each have their own HDMI connector.
In
- Ethernet
- Gigabit, 10/100/1000
- Wi-Fi
- 802.11a/b/g/n/ac, 2.4 and 5 GHz
- Bluetooth
- 5.0
- USB-A host
- Flash drives, HDD/SSD, USB optical drive
- NVMe
- PCIe SSD up to 16 TB
- Power
- 115–230 V AC on IEC C13 socket with fuses
Out
- USB DAC
- USB-A 2.0 with power filtering and signal-integrity reconstruction
- I2S/DSD
- HDMI connector with adjustable pinout routing
- AES/EBU
- XLR connector
- S/PDIF coaxial
- BNC connector
- S/PDIF coaxial
- RCA connector
- S/PDIF optical
- TOSLINK connector × 2
- Video
- HDMI connector, mirrors Volumio on your TV (up to 4K)
- Trigger
- 12 V on a 3.5 mm jack, positive on tip
Displays
See what you hear
Main display
The 12″ touchscreen display is a new way to touch your music for a truly immersive listening experience. This glorious display features the most innovative and fulfilling interface to make music a full sensory experience.
Knob display
The secondary display provides useful information at a glance, complementing the built-in status LED.
Bit-perfect
True high-fidelity shouldn’t feel like a technical challenge or constraint. Rivo Ultra is powered by a highly customised version of Volumio OS delivering bit-perfect digital audio to your system.
Main display
12 ways to see your music
VU meters, spectrums, the album cover or a clock. Pick a screen on the display itself or in the Volumio app.
Screens from the Rivo Ultra software, shown with a fictional album.
The Volumio experience
Rivo Ultra runs Volumio OS, the player behind 800,000+ devices. You play it from the Volumio app, free on iPhone and Android.
Volumio OS inside
Premium features built in
Your music, your way
High quality extends beyond just superb audio performance. Volumio Premium built in. Stream with your TIDAL, Qobuz or Spotify account, plus their Connect features and AirPlay. Play local or network drives, or internet radio.
The Premium features belong to this Rivo Ultra, with no subscription. On a Raspberry Pi or a PC, the same features come with a Volumio Premium subscription.
On the display
Control everything from the 12″ touchscreen on the front panel.
On your TV
Connect via the HDMI video output and turn your living room into a music temple.
In your hand
Full control from the Volumio app on iOS and Android, or with the IR remote.
Supersearch
An AI-powered search that helps you discover music.
Multiroom
Links Rivo Ultra with the other Volumio players in your home.
Roon Ready
Certified by Roon Labs, so Rivo Ultra works with Roon.
Finishes
Full aluminum or aluminum and leather
Rivo Ultra comes in two finishes.
Full aluminum
An aluminum case, top included.
Aluminum and leather
An aluminum case with a stitched black leather top.
Compare
Rivo Ultra or Rivo Plus
Both are streamer transports with the Premium features built in. Rivo Ultra has the better USB DAC output, with a temperature-compensated clock (TCXO) and cleaner power from its integrated linear power supply and an additional linear stage on the main board. It also adds a femto-clock for the integrated outputs, S/PDIF optical and BNC outputs, a 12-inch touchscreen and an NVMe slot for your music.
Rivo Ultra
Our flagship streamer
Buy, Rivo Ultra
Rivo Plus
The enhanced Rivo
Buy, Rivo Plus
- Clock
- Rivo Ultra: Femto-clock, 54 fs RMS phase noise, for the integrated outputs; TCXO for the USB hub
- Rivo Plus: MEMS clocks for the USB hub and the output ASIC
- Power supply
- Rivo Ultra: Internal dual linear supply, 115–230 V AC
- Rivo Plus: External 5 V DC / 3 A
- I2S over HDMI output
- Rivo Ultra: Up to PCM 768 kHz / 32-bit and DSD1024
- Rivo Plus: Up to PCM 768 kHz / 32-bit and DSD512
- S/PDIF coaxial output
- Rivo Ultra: RCA and BNC
- Rivo Plus: RCA
- S/PDIF optical output
- Rivo Ultra: 2 × TOSLINK, up to PCM 192 kHz / 24-bit and DSD64 via DoP
- Rivo Plus: Not available
- Display and remote
- Rivo Ultra: 12″ touchscreen, a knob with its own display, Remoto included
- Storage for your music
- Rivo Ultra: NVMe slot for a PCIe SSD up to 16 TB, plus USB drives
- Rivo Plus: USB drives
- Processor
- Rivo Ultra: ARM Cortex-A76, quad-core, 2.4 GHz
- Rivo Plus: ARM Cortex-A55, quad-core, 1.9 GHz
- Size and weight
- Rivo Ultra: 44 × 34 × 9 cm, 6 kg
- Rivo Plus: 27 × 15 × 5.2 cm, 1.12 kg
- Finishes
- Rivo Ultra: Full aluminum, or aluminum and leather
- Rivo Plus: Classic, or the Special Edition in brown leather
- On both
- USB DAC output up to PCM 1536 kHz / 32-bit and DSD1024, with multiroom off. AES/EBU and S/PDIF coaxial up to PCM 192 kHz / 24-bit and DSD64 via DoP. 2 GB DDR4 and 16 GB eMMC. Gigabit Ethernet, dual-band Wi-Fi and Bluetooth 5.0. HDMI up to 4K / 60 fps. 12 V trigger. Premium features built in.
means not available on that model.
Rivo Ultra
Tech specs
Audio
- Master clock
- Femto-clock with ultra-low phase noise (54 fs RMS) and jitter on the integrated outputs; temperature-compensated clock (TCXO) on the USB DAC output
- Digital signal interface
- Custom integration of Amanero768
- Volume adjustment
- Hardware, if supported by the connected DAC, otherwise Software or None
Digital outputs
- USB output
- Up to PCM 1536 kHz / 32 bit and DSD1024, with multiroom off
- I2S/DSD over HDMI output
- Up to PCM 768 kHz / 32 bit and DSD1024, with multiroom off
- Up to PCM 192 kHz / 24 bit and DSD64 via DoP
- AES/EBU output
Software and services
- Supported formats
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 and others
- Supported services
- AirPlay via Shairport Sync, Spotify Connect, TIDAL and TIDAL Connect, Qobuz and Qobuz Connect, Roon
- UPnP/DLNA
- Renderer with OpenHome support
- Plugins
- Squeezelite, Radio Paradise, Podcasts, Pandora, Fusion DSP, SoundCloud, Mixcloud
Connectors
- USB DAC output
- 1 × USB-A 2.0 with power filtering and signal-integrity reconstruction
- USB host
- 1 × USB-C, 3 × USB-A 3.0 (USB Flash Drive and HDD/SSD)
- I2S/DSD output
- 1 × HDMI with adjustable pinout routing
- 1 × RCA, 1 × BNC
- 2 × TOSLINK
- AES/EBU output
- 1 × XLR
- Video output
- Volumio OS app mirroring over HDMI up to 4K / 60 fps
- Trigger out
- 1 × 3.5 mm jack (12 V, positive on tip)
Network
- LAN
- Gigabit 10/100/1000 Mbps
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2.4 GHz and 5 GHz
- Bluetooth
- 5.0
Processor and storage
- CPU
- ARM Cortex-A76, Quad Core 2.4 GHz
- RAM
- 2 GB DDR4
- Internal storage
- 16 GB eMMC
- Expansion slot
- NVMe slot for a PCIe SSD, up to 16 TB
- Real-time clock
- Built in (needs 1 × CR2032 battery)
Display and controls
- Display
- 12″ TFT LCD touchscreen (adjustable brightness)
- Knob
- Rotary knob with push-button and its own display (adjustable brightness)
- Remote
- Remoto IR remote control (included)
Power
- Power supply
- Dual linear power supply with a dedicated audio-grade transformer
- Circuit protection
- 2 × fuse (1.25 A T), easy to reach
- Power
- 115–230 V AC, with a manual voltage selector
- Power input
- AC power cord (IEC C13)
Size and finishes
- Finishes
- Full aluminum, or aluminum with a leather top
- Dimensions
- 44 × 34 × 9 cm (17.3 × 13.4 × 3.5 in)
- Weight
- 6 kg (13.2 lb)
In the box
- Rivo Ultra
- Remoto (remote control)
- Wi-Fi antenna
- NFC card
- Power cord
Owner reviews
What Rivo Ultra owners say
Die Highlights
- Bitgenaue WiedergabeMit einer auf Rivo Ultra abgestimmten Version von Volumio OS.
- Extrem rauscharm, geringer JitterFemto-Taktgeber mit 54 fs RMS Phasenrauschen an den integrierten Ausgängen. Temperaturkompensierter Taktgeber (TCXO) am USB-DAC-Ausgang.
- Große Auswahl an DigitalausgängenSieben Ausgänge: USB, I2S/DSD über HDMI, AES/EBU, zwei S/PDIF koaxial (einer mit BNC-, einer mit Cinch-Anschluss) und zwei S/PDIF optisch.
- Lineares NetzteilZwei unabhängige lineare Regelstufen, gespeist von einem audiophilen Ringkerntransformator.
- Erweiterungssteckplatz für SSDsBis zu 16 TB für Ihre Musikbibliothek.
- Ultrabreiter Touchscreen12 Zoll an der Front, dazu ein Display im Drehknopf.
- Fortschrittliche, anpassbare OberflächeVolumio OS an Bord, Volumio Premium integriert. Funktioniert mit TIDAL, Qobuz, Spotify Connect, AirPlay und Roon Ready.
Rivo Ultra ist unser Flaggschiff-Streamer, mit einer Version von Volumio OS, die auf sein Design abgestimmt ist.
Hergestellt in Florenz
Von Hand entworfen, montiert und geprüft, in Italien
Rivo Ultra wird in Florenz, Italien, entworfen, wo jedes Gerät von Hand montiert und geprüft wird. Ein Team unter einem Dach, das Hardware und Software gemeinsam entwickelt und fertigt. Jedes Gerät wird gründlich geprüft und sorgfältig verpackt, bevor wir es an Sie senden.
Mehr über Volumio in FlorenzEin Blick ins Innere
Der raffinierteste Streamer, den wir je gebaut haben.
Rivo Ultra ist der ultimative Streaming-Transport, die perfekte Verbindung von audiotauglicher Hardware und Software-Design. Er ist die Weiterentwicklung der besten Technik, die wir entwickelt haben, auf ein neues audiophiles Niveau gehoben.
Ausgänge
5 Wege zu Ihrem DAC
Rivo Ultra ist ein Streaming-Transport. Er schickt das Signal über USB, I2S/DSD über HDMI, AES/EBU, S/PDIF koaxial oder S/PDIF optisch an Ihren DAC. Ein 12-V-Trigger schaltet Ihre anderen Komponenten ein und aus.
USB-DAC
1536kHz
Bis zu PCM 1536 kHz / 32 Bit und DSD1024 (oder DSD256 bei aktiviertem Multiroom-Audio). Der USB-DAC-Ausgang bietet Stromfilterung und eine Rekonstruktion der Signalintegrität. Bei kompatiblen DACs lässt sich die Lautstärke über Rivo Ultra regeln.
I2S/DSD über HDMI
768kHz
Bis zu PCM 768 kHz / 32 Bit und DSD1024 (oder DSD256 bei aktiviertem Multiroom-Audio). Die Pinbelegung des HDMI-Anschlusses ist anpassbar, damit Rivo Ultra zu Ihrem DAC passt.
AES/EBU
192kHz
Bis zu PCM 192 kHz / 24 Bit und DSD64 (DoP), als symmetrischer Digitalausgang.
S/PDIF koaxial
192kHz
Bis zu PCM 192 kHz / 24 Bit und DSD64 (DoP), über Cinch- und BNC-Anschlüsse für maximale Flexibilität.
S/PDIF optisch
192kHz
Bis zu PCM 192 kHz / 24 Bit und DSD64 (DoP), mit 2 Ausgängen über TOSLINK-Anschlüsse.
Anschlüsse
Von Ihrem Netzwerk zu Ihrem DAC
Streamen Sie über Gigabit-Ethernet oder Dualband-WLAN, oder spielen Sie von der internen SSD und von USB-Laufwerken ab. Auf der Rückseite haben I2S/DSD und Video je einen eigenen HDMI-Anschluss.
Eingänge
- Ethernet
- WLAN
- 802.11a/b/g/n/ac, 2,4 und 5 GHz
- Bluetooth
- 5.0
- USB-A-Host
- USB-Sticks, HDD/SSD, optisches USB-Laufwerk
- NVMe
- PCIe-SSD bis zu 16 TB
- Stromversorgung
- 115–230 V AC an IEC-C13-Buchse mit Sicherungen
Ausgänge
- USB-DAC
- USB-A 2.0 mit Stromfilterung und Rekonstruktion der Signalintegrität
- I2S/DSD
- HDMI-Anschluss mit anpassbarer Pinbelegung
- AES/EBU
- XLR-Anschluss
- S/PDIF koaxial
- BNC-Anschluss
- S/PDIF koaxial
- Cinch-Anschluss
- S/PDIF optisch
- TOSLINK-Anschluss × 2
- Video
- HDMI-Anschluss, zeigt Volumio auf Ihrem Fernseher (bis 4K)
- Trigger
- 12 V über 3,5-mm-Klinke, Spitze positiv
Bildschirme
Sehen, was Sie hören
Hauptdisplay
Der 12″-Touchscreen ist eine neue Art, Ihre Musik zu berühren, für ein wirklich immersives Hörerlebnis. Dieses herrliche Display bietet die innovativste und erfüllendste Oberfläche und macht Musik zu einem Erlebnis für alle Sinne.
Das zweite Display zeigt nützliche Informationen auf einen Blick und ergänzt die eingebaute Status-LED.
Bitgenau
Echtes High-End sollte weder eine technische Herausforderung noch eine Einschränkung sein. Rivo Ultra läuft mit einer stark angepassten Version von Volumio OS, die bitgenaues Digitalaudio an Ihre Anlage liefert.
Hauptdisplay
12 Arten, Ihre Musik zu sehen
VU-Meter, Spektren, das Albumcover oder eine Uhr. Wählen Sie einen Screen direkt am Display oder in der Volumio-App.
Screens aus der Rivo-Ultra-Software, gezeigt mit einem fiktiven Album.
Das Volumio-Erlebnis
Volumio OS an Bord. Die App in der Hand.
Rivo Ultra läuft mit Volumio OS, dem Player hinter 800.000+ Geräten. Sie bedienen ihn mit der Volumio-App, kostenlos für iPhone und Android.
Volumio OS an Bord
Premium-Funktionen integriert
Ihre Musik, wie Sie es wollen
Hohe Qualität geht über hervorragenden Klang hinaus. Volumio Premium integriert. Streamen Sie mit Ihrem TIDAL-, Qobuz- oder Spotify-Konto, dazu deren Connect-Funktionen und AirPlay. Spielen Sie von lokalen oder Netzlaufwerken ab, oder hören Sie Internetradio.
Die Premium-Funktionen gehören zu diesem Rivo Ultra, ohne Abo. Auf einem Raspberry Pi oder PC gibt es dieselben Funktionen mit einem Volumio Premium-Abo.
Auf dem Display
Steuern Sie alles über den 12″-Touchscreen an der Front.
Auf Ihrem Fernseher
Verbinden Sie den HDMI-Videoausgang und machen Sie Ihr Wohnzimmer zum Musiktempel.
In Ihrer Hand
Volle Kontrolle mit der Volumio-App für iOS und Android oder mit der IR-Fernbedienung.
Super-Suche
Eine KI-gestützte Suche, mit der Sie neue Musik entdecken.
Multiroom
Verbindet Rivo Ultra mit den anderen Volumio-Playern in Ihrem Zuhause.
Roon Ready
Von Roon Labs zertifiziert: Rivo Ultra funktioniert mit Roon.
Ausführungen
Vollaluminium oder Aluminium und Leder
Rivo Ultra gibt es in zwei Ausführungen.
Vollaluminium
Ein Aluminiumgehäuse, inklusive Deckel.
Aluminium und Leder
Ein Aluminiumgehäuse mit einem Deckel aus genähtem schwarzem Leder.
Vergleichen
Rivo Ultra oder Rivo Plus
Beide sind Streamer-Transporte mit integrierten Premium-Funktionen. Rivo Ultra hat den besseren USB-DAC-Ausgang, mit einem temperaturkompensierten Taktgeber (TCXO) und sauberer Stromversorgung dank des integrierten linearen Netzteils und einer zusätzlichen linearen Stufe auf der Hauptplatine. Dazu kommen ein Femto-Taktgeber für die integrierten Ausgänge, optische S/PDIF- und BNC-Ausgänge, ein 12-Zoll-Touchscreen und ein NVMe-Steckplatz für Ihre Musik.
Rivo Ultra
Unser Flaggschiff-Streamer
Kaufen, Rivo Ultra
Rivo Plus
Der erweiterte Rivo
Kaufen, Rivo Plus
- Taktgeber
- Rivo Ultra: Femto-Taktgeber, 54 fs RMS Phasenrauschen, für die integrierten Ausgänge; TCXO für den USB-Hub
- Rivo Plus: MEMS-Taktgeber für den USB-Hub und den Ausgangs-ASIC
- Netzteil
- Rivo Ultra: Internes duales lineares Netzteil, 115–230 V AC
- Rivo Plus: Extern, 5 V DC / 3 A
- I2S-Ausgang (HDMI)
- Rivo Ultra: Bis zu PCM 768 kHz / 32 Bit und DSD1024
- Rivo Plus: Bis zu PCM 768 kHz / 32 Bit und DSD512
- Koaxialer S/PDIF-Ausgang
- Rivo Ultra: Cinch und BNC
- Rivo Plus: Cinch
- Optischer S/PDIF-Ausgang
- Rivo Ultra: 2 × TOSLINK, bis zu PCM 192 kHz / 24 Bit und DSD64 über DoP
- Rivo Plus: Nicht verfügbar
- Display und Fernbedienung
- Rivo Ultra: 12″-Touchscreen, ein Drehknopf mit eigenem Display, Remoto im Lieferumfang
- Speicher für Ihre Musik
- Rivo Ultra: NVMe-Steckplatz für eine PCIe-SSD bis 16 TB, dazu USB-Laufwerke
- Rivo Plus: USB-Laufwerke
- Prozessor
- Rivo Ultra: ARM Cortex-A76, Quad-Core, 2,4 GHz
- Rivo Plus: ARM Cortex-A55, Quad-Core, 1,9 GHz
- Größe und Gewicht
- Rivo Plus: 27 × 15 × 5,2 cm, 1,12 kg
- Ausführungen
- Rivo Ultra: Vollaluminium oder Aluminium und Leder
- Rivo Plus: Classic oder die Special Edition in braunem Leder
- Bei beiden
- USB-DAC-Ausgang bis zu PCM 1536 kHz / 32 Bit und DSD1024, bei deaktiviertem Multiroom. AES/EBU und S/PDIF koaxial bis zu PCM 192 kHz / 24 Bit und DSD64 über DoP. 2 GB DDR4 und 16 GB eMMC. Gigabit-Ethernet, Dualband-WLAN und Bluetooth 5.0. HDMI bis 4K / 60 fps. 12-V-Trigger. Premium-Funktionen integriert.
bedeutet: bei diesem Modell nicht verfügbar.
Rivo Ultra
Technische Daten
Audio
- Master-Taktgeber
- Femto-Taktgeber mit extrem niedrigem Phasenrauschen (54 fs RMS) und Jitter an den integrierten Ausgängen; temperaturkompensierter Taktgeber (TCXO) am USB-DAC-Ausgang
- Digitale Signalschnittstelle
- Individuelle Integration von Amanero768
- Lautstärkeregelung
- Hardware, sofern vom angeschlossenen DAC unterstützt, sonst Software oder keine
Digitale Ausgänge
- USB-Ausgang
- Bis zu PCM 1536 kHz / 32 Bit und DSD1024, bei deaktiviertem Multiroom
- I2S/DSD-Ausgang (HDMI)
- Bis zu PCM 768 kHz / 32 Bit und DSD1024, bei deaktiviertem Multiroom
- Bis zu PCM 192 kHz / 24 Bit und DSD64 über DoP
- AES/EBU-Ausgang
Software und Dienste
- Unterstützte Formate
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 und weitere
- Unterstützte Dienste
- AirPlay über Shairport Sync, Spotify Connect, TIDAL und TIDAL Connect, Qobuz und Qobuz Connect, Roon
- UPnP/DLNA
- Renderer mit OpenHome-Unterstützung
- Plugins
Anschlüsse
- USB-DAC-Ausgang
- 1 × USB-A 2.0 mit Stromfilterung und Rekonstruktion der Signalintegrität
- USB-Host
- 1 × USB-C, 3 × USB-A 3.0 (USB-Sticks und HDD/SSD)
- I2S/DSD-Ausgang
- 1 × HDMI mit anpassbarer Pinbelegung
- 1 × Cinch, 1 × BNC
- 2 × TOSLINK
- AES/EBU-Ausgang
- 1 × XLR
- Videoausgang
- Spiegelung der Volumio-App über HDMI, bis zu 4K / 60 fps
- Trigger-Ausgang
- 1 × 3,5-mm-Klinke (12 V, Spitze positiv)
Netzwerk
- LAN
- WLAN
- WLAN 802.11a/b/g/n/ac, 2,4 GHz und 5 GHz
- Bluetooth
- 5.0
Prozessor und Speicher
- CPU
- ARM Cortex-A76, Quad-Core 2,4 GHz
- RAM
- 2 GB DDR4
- Interner Speicher
- 16 GB eMMC
- NVMe-Steckplatz für eine PCIe-SSD, bis zu 16 TB
- Echtzeituhr
- Integriert (benötigt 1 × CR2032-Batterie)
Display und Bedienelemente
- Display
- 12″-TFT-LCD-Touchscreen (Helligkeit einstellbar)
- Drehknopf
- Drehknopf mit Drucktaste und eigenem Display (Helligkeit einstellbar)
- Fernbedienung
- Remoto IR-Fernbedienung (im Lieferumfang)
Stromversorgung
- Netzteil
- Duales lineares Netzteil mit eigenem audiotauglichem Transformator
- Schutzschaltung
- 2 × Sicherung (1,25 A T), leicht zugänglich
- Stromversorgung
- 115–230 V AC, mit manuellem Spannungswahlschalter
- Stromeingang
- Netzkabel (IEC C13)
Größe und Ausführungen
- Ausführungen
- Vollaluminium oder Aluminium mit Lederdeckel
- Abmessungen
- 44 × 34 × 9 cm (17,3 × 13,4 × 3,5 in)
- Gewicht
- 6 kg (13,2 lb)
Lieferumfang
- Rivo Ultra
- Remoto (Fernbedienung)
- WLAN-Antenne
- NFC-Karte
- Netzkabel
Kundenbewertungen
Was Besitzer von Rivo Ultra sagen
Bewertungen verifizierter Käufer auf shop.volumio.com, gesammelt von REVIEWS.io. Unverändert wiedergegeben, in der Sprache der Verfasser.
In evidenza
- Riproduzione bit-perfectDa una versione di Volumio OS ottimizzata per Rivo Ultra.
- Rumore bassissimo e jitter ridottoFemto-clock con rumore di fase di 54 fs RMS sulle uscite integrate. Clock compensato in temperatura (TCXO) sull’uscita USB DAC.
- Un’ampia scelta di uscite digitaliSette uscite: USB, I2S/DSD su HDMI, AES/EBU, due S/PDIF coassiali (una su connettore BNC, una su RCA) e due S/PDIF ottiche.
- Alimentatore lineareDue stadi di regolazione lineare indipendenti, alimentati da un trasformatore toroidale di livello audiofilo.
- Slot di espansione per SSDFino a 16 TB per la tua libreria musicale.
- Display touch screen ultra-wide12 pollici sul frontale, più un display nella manopola.
- Interfaccia avanzata e personalizzabileVolumio OS a bordo, Volumio Premium incluso. Compatibile con TIDAL, Qobuz, Spotify Connect, AirPlay e Roon Ready.
Rivo Ultra è il nostro streamer di punta, con una versione di Volumio OS ottimizzata per il suo design.
Realizzato a Firenze
Progettato, assemblato e testato a mano, in Italia
Rivo Ultra è progettato a Firenze, dove ogni unità viene assemblata e testata a mano. Un unico team sotto lo stesso tetto, che progetta e realizza sia l'hardware sia il software. Ogni unità viene testata a fondo e imballata con cura prima di arrivare a te.
Scopri di più su Volumio a FirenzeUno sguardo all'interno
Lo streamer più raffinato che abbiamo mai creato.
Rivo Ultra rappresenta il transport digitale definitivo, la sinergia perfetta tra hardware di qualità audio e progettazione software. È l'evoluzione della migliore tecnologia che abbiamo sviluppato, portata a nuove vette audiofile.
Uscite
5 strade verso il tuo DAC
Rivo Ultra è un transport digitale. Invia il segnale al tuo DAC via USB, I2S/DSD su HDMI, AES/EBU, S/PDIF coassiale o S/PDIF ottica. Un trigger a 12 V accende e spegne gli altri componenti.
USB DAC
1536kHz
Fino a PCM 1536 kHz / 32-bit e DSD1024 (o DSD256 con l'audio multiroom attivo). L'uscita USB DAC dispone di alimentazione filtrata e ricostruzione dell'integrità del segnale. Con i DAC compatibili, il volume si regola da Rivo Ultra.
I2S/DSD su HDMI
768kHz
Fino a PCM 768 kHz / 32-bit e DSD1024 (o DSD256 con l'audio multiroom attivo). L'assegnazione dei pin del connettore HDMI è regolabile, per abbinare Rivo Ultra al tuo DAC.
AES/EBU
192kHz
Fino a PCM 192 kHz / 24-bit e DSD64 (DoP), per un'uscita digitale bilanciata.
S/PDIF coassiale
192kHz
Fino a PCM 192 kHz / 24-bit e DSD64 (DoP), su connettori RCA e BNC per la massima flessibilità.
S/PDIF ottico
192kHz
Fino a PCM 192 kHz / 24-bit e DSD64 (DoP), con 2 uscite su connettori TOSLINK.
Connessioni
Dalla rete al tuo DAC
Ascolta in streaming via Gigabit Ethernet o Wi-Fi dual band, oppure dall’SSD interno e da unità USB. Sul retro, I2S/DSD e video hanno ciascuno il proprio connettore HDMI.
Ingressi
- Ethernet
- Wi-Fi
- 802.11a/b/g/n/ac, 2,4 e 5 GHz
- Bluetooth
- 5.0
- USB-A host
- Chiavette, HDD/SSD, lettore ottico USB
- NVMe
- SSD PCIe fino a 16 TB
- Alimentazione
- 115–230 V AC su presa IEC C13 con fusibili
Uscite
- USB DAC
- USB-A 2.0 con alimentazione filtrata e ricostruzione dell'integrità del segnale
- I2S/DSD
- Connettore HDMI con assegnazione dei pin regolabile
- AES/EBU
- Connettore XLR
- S/PDIF coassiale
- Connettore BNC
- S/PDIF coassiale
- Connettore RCA
- S/PDIF ottico
- Connettore TOSLINK × 2
- Video
- Connettore HDMI, mostra Volumio sulla tua TV (fino a 4K)
- Trigger
- 12 V su jack da 3,5 mm, positivo sulla punta
Schermi
Guarda ciò che ascolti
Display principale
Il touch screen da 12″ è un nuovo modo di toccare la tua musica, per un ascolto davvero immersivo. Questo splendido display offre l'interfaccia più innovativa e appagante, per fare della musica un'esperienza per tutti i sensi.
Display della manopola
Il display secondario mostra a colpo d'occhio le informazioni utili, a complemento del LED di stato integrato.
Bit-perfect
La vera alta fedeltà non dovrebbe essere una sfida tecnica né un vincolo. Rivo Ultra funziona con una versione altamente personalizzata di Volumio OS, che invia al tuo impianto audio digitale bit-perfect.
Display principale
12 modi di vedere la tua musica
VU meter, spettri, la copertina dell’album o un orologio. Scegli una schermata direttamente sul display o nell’app Volumio.
Schermate del software di Rivo Ultra, mostrate con un album immaginario.
L'esperienza Volumio
Volumio OS a bordo. L'app nelle tue mani.
Rivo Ultra usa Volumio OS, il lettore che fa suonare oltre 800.000 dispositivi. Lo controlli dall'app Volumio, gratuita per iPhone e Android.
Volumio OS a bordo
Funzioni Premium incluse
La tua musica, a modo tuo
L'alta qualità va oltre un suono semplicemente eccellente. Volumio Premium incluso. Ascolta in streaming con il tuo account TIDAL, Qobuz o Spotify, più le loro funzioni Connect e AirPlay. Riproduci da unità locali o di rete, o ascolta la radio via internet.
Le funzioni Premium restano legate a questo Rivo Ultra, senza abbonamento. Su un Raspberry Pi o un PC, le stesse funzioni richiedono un abbonamento a Volumio Premium.
Sul display
Controlla tutto dal touch screen da 12″ sul pannello frontale.
Sulla tua TV
Collegati tramite l'uscita video HDMI e trasforma il tuo soggiorno in un tempio della musica.
Nelle tue mani
Pieno controllo dall'app Volumio per iOS e Android, o con il telecomando IR.
Super ricerca
Una ricerca basata sull'AI che ti aiuta a scoprire nuova musica.
Multiroom
Collega Rivo Ultra agli altri lettori Volumio di casa.
Roon Ready
Certificato da Roon Labs: Rivo Ultra funziona con Roon.
Finiture
Tutto alluminio o alluminio e pelle
Rivo Ultra è disponibile in due finiture.
Tutto alluminio
Un case in alluminio, piano superiore compreso.
Alluminio e pelle
Un case in alluminio con il piano superiore in pelle nera cucita.
Confronta
Rivo Ultra o Rivo Plus
Entrambi sono streamer transport con le funzioni Premium incluse. Rivo Ultra ha l’uscita USB DAC migliore, con un clock compensato in temperatura (TCXO) e un’alimentazione più pulita grazie all’alimentatore lineare integrato e a un ulteriore stadio lineare sulla scheda madre. Aggiunge anche un femto-clock per le uscite integrate, uscite S/PDIF ottiche e BNC, un touch screen da 12 pollici e uno slot NVMe per la tua musica.
Rivo Ultra
Il nostro streamer di punta
Acquista, Rivo Ultra
Rivo Plus
Il Rivo potenziato
Acquista, Rivo Plus
- Clock
- Rivo Ultra: Femto-clock, rumore di fase 54 fs RMS, per le uscite integrate; TCXO per l’hub USB
- Rivo Plus: Clock MEMS per l'hub USB e l'ASIC delle uscite
- Alimentatore
- Rivo Ultra: Alimentatore lineare doppio interno, 115–230 V AC
- Rivo Plus: Esterno 5 V DC / 3 A
- Uscita I2S su HDMI
- Rivo Ultra: Fino a PCM 768 kHz / 32-bit e DSD1024
- Rivo Plus: Fino a PCM 768 kHz / 32-bit e DSD512
- Uscita S/PDIF coassiale
- Rivo Ultra: RCA e BNC
- Rivo Plus: RCA
- Uscita S/PDIF ottica
- Rivo Ultra: 2 × TOSLINK, fino a PCM 192 kHz / 24-bit e DSD64 via DoP
- Rivo Plus: Non disponibile
- Display e telecomando
- Rivo Ultra: Touch screen da 12″, una manopola con il proprio display, Remoto incluso
- Spazio per la tua musica
- Rivo Ultra: Slot NVMe per un SSD PCIe fino a 16 TB, più le unità USB
- Rivo Plus: Unità USB
- Processore
- Rivo Ultra: ARM Cortex-A76, quad-core, 2,4 GHz
- Rivo Plus: ARM Cortex-A55, quad-core, 1,9 GHz
- Dimensioni e peso
- Finiture
- Rivo Ultra: Tutto alluminio, o alluminio e pelle
- Rivo Plus: Classic, o la Special Edition in pelle marrone
- In comune
- Uscita USB DAC fino a PCM 1536 kHz / 32-bit e DSD1024, con multiroom disattivato. AES/EBU e S/PDIF coassiale fino a PCM 192 kHz / 24-bit e DSD64 via DoP. 2 GB DDR4 e 16 GB eMMC. Gigabit Ethernet, Wi-Fi dual band e Bluetooth 5.0. HDMI fino a 4K / 60 fps. Trigger a 12 V. Funzioni Premium incluse.
significa non disponibile su quel modello.
Rivo Ultra
Specifiche
Audio
- Master clock
- Femto-clock con rumore di fase (54 fs RMS) e jitter bassissimi sulle uscite integrate; clock compensato in temperatura (TCXO) sull’uscita USB DAC
- Interfaccia del segnale digitale
- Integrazione personalizzata di Amanero768
- Regolazione del volume
- Hardware, se supportata dal DAC collegato, altrimenti software o nessuna
Uscite digitali
- Uscita USB
- Fino a PCM 1536 kHz / 32 bit e DSD1024, con multiroom disattivato
- Uscita I2S/DSD su HDMI
- Fino a PCM 768 kHz / 32 bit e DSD1024, con multiroom disattivato
- Fino a PCM 192 kHz / 24 bit e DSD64 via DoP
- Uscita AES/EBU
Software e servizi
- Formati supportati
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 e altri
- Servizi supportati
- AirPlay via Shairport Sync, Spotify Connect, TIDAL e TIDAL Connect, Qobuz e Qobuz Connect, Roon
- UPnP/DLNA
- Renderer con supporto OpenHome
- Plugin
- Squeezelite, Radio Paradise, Podcast, Pandora, Fusion DSP, SoundCloud, Mixcloud
Connettori
- Uscita USB DAC
- 1 × USB-A 2.0 con alimentazione filtrata e ricostruzione dell'integrità del segnale
- USB host
- 1 × USB-C, 3 × USB-A 3.0 (chiavette USB e HDD/SSD)
- Uscita I2S/DSD
- 1 × HDMI con assegnazione dei pin regolabile
- 1 × RCA, 1 × BNC
- 2 × TOSLINK
- Uscita AES/EBU
- 1 × XLR
- Uscita video
- Mirroring dell'app Volumio OS via HDMI fino a 4K / 60 fps
- Uscita trigger
- 1 × jack da 3,5 mm (12 V, positivo sulla punta)
Rete
- LAN
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2,4 GHz e 5 GHz
- Bluetooth
- 5.0
Processore e memoria
- CPU
- ARM Cortex-A76, Quad Core 2,4 GHz
- RAM
- 2 GB DDR4
- Archiviazione interna
- 16 GB eMMC
- Slot NVMe per un SSD PCIe, fino a 16 TB
- Orologio in tempo reale
- Integrato (richiede 1 batteria CR2032)
Display e comandi
- Display
- Touch screen TFT LCD da 12″ (luminosità regolabile)
- Manopola
- Manopola rotativa con pulsante e display proprio (luminosità regolabile)
- Telecomando
- Telecomando IR Remoto (incluso)
Alimentazione
- Alimentatore
- Alimentatore lineare doppio con trasformatore dedicato di qualità audio
- Protezione del circuito
- 2 × fusibile (1,25 A T), facilmente accessibili
- Alimentazione
- 115–230 V AC, con selettore di tensione manuale
- Ingresso di alimentazione
- Cavo di alimentazione AC (IEC C13)
Dimensioni e finiture
- Finiture
- Tutto alluminio, o alluminio con piano superiore in pelle
- Dimensioni
- Peso
- 6 kg (13,2 lb)
Nella confezione
- Rivo Ultra
- Remoto (telecomando)
- Antenna Wi-Fi
- Scheda NFC
Recensioni dei proprietari
Il parere di chi ha Rivo Ultra
Scrivi una recensione nello shop
Recensioni di acquirenti verificati su shop.volumio.com, raccolte da REVIEWS.io. Mostrate così come sono state scritte, nella lingua dell'autore.
Les points forts
- Lecture bit-perfectGrâce à une version de Volumio OS optimisée pour le Rivo Ultra.
- Bruit ultra-faible et jitter réduitHorloge femto avec un bruit de phase de 54 fs RMS sur les sorties intégrées. Horloge compensée en température (TCXO) sur la sortie USB DAC.
- Un large choix de sorties numériquesSept sorties : USB, I2S/DSD sur HDMI, AES/EBU, deux S/PDIF coaxiales (l’une sur connecteur BNC, l’autre sur RCA) et deux S/PDIF optiques.
- Alimentation linéaireDeux étages de régulation linéaire indépendants, alimentés par un transformateur torique de qualité audiophile.
- Emplacement d’extension pour SSDJusqu’à 16 To pour votre bibliothèque musicale.
- Écran tactile ultra-large12 pouces en façade, plus un écran dans le bouton rotatif.
- Interface avancée et personnalisableVolumio OS à bord, Volumio Premium inclus. Compatible TIDAL, Qobuz, Spotify Connect, AirPlay et Roon Ready.
Le Rivo Ultra est notre streamer phare, animé par une version de Volumio OS optimisée pour sa conception.
Fabriqué à Florence
Conçu, assemblé et testé à la main, en Italie
Le Rivo Ultra est conçu à Florence, en Italie, où chaque appareil est assemblé et testé à la main. Une seule équipe, sous le même toit, qui conçoit et fabrique le matériel comme le logiciel. Chaque appareil est minutieusement testé et soigneusement emballé avant de vous être expédié.
En savoir plus sur Volumio à FlorenceVue intérieure
Le streamer le plus abouti que nous ayons jamais créé.
Le Rivo Ultra incarne le transport numérique ultime, la synergie parfaite entre un matériel de qualité audio et la conception logicielle. C’est l’évolution de la meilleure technologie que nous ayons développée, portée vers de nouveaux sommets audiophiles.
Sorties
5 façons de rejoindre votre DAC
Le Rivo Ultra est un transport numérique. Il envoie le signal à votre DAC en USB, en I2S/DSD sur HDMI, en AES/EBU, en S/PDIF coaxial ou en S/PDIF optique. Un trigger 12 V allume et éteint vos autres appareils.
DAC USB
1536kHz
Jusqu’à PCM 1536 kHz / 32-bit et DSD1024 (ou DSD256 lorsque l’audio multiroom est activé). La sortie USB DAC dispose d’un filtrage de l’alimentation et d’une reconstruction de l’intégrité du signal. Avec les DAC compatibles, le volume se règle depuis le Rivo Ultra.
I2S/DSD sur HDMI
768kHz
Jusqu’à PCM 768 kHz / 32-bit et DSD1024 (ou DSD256 lorsque l’audio multiroom est activé). Le brochage du connecteur HDMI est configurable pour accorder le Rivo Ultra à votre DAC.
AES/EBU
192kHz
Jusqu’à PCM 192 kHz / 24-bit et DSD64 (DoP), pour une sortie numérique symétrique.
S/PDIF coaxiale
192kHz
Jusqu’à PCM 192 kHz / 24-bit et DSD64 (DoP), sur connecteurs RCA et BNC pour une souplesse maximale.
S/PDIF optique
192kHz
Jusqu’à PCM 192 kHz / 24-bit et DSD64 (DoP), avec 2 sorties sur connecteurs TOSLINK.
Connectique
De votre réseau à votre DAC
Diffusez en Gigabit Ethernet ou en Wi-Fi double bande, ou lisez depuis le SSD interne et des disques USB. À l’arrière, l’I2S/DSD et la vidéo ont chacun leur propre connecteur HDMI.
Entrées
- Ethernet
- Wi-Fi
- 802.11a/b/g/n/ac, 2,4 et 5 GHz
- Bluetooth
- 5.0
- USB-A hôte
- Clés USB, disques durs/SSD, lecteur optique USB
- NVMe
- SSD PCIe jusqu’à 16 To
- Alimentation
- 115–230 V AC sur prise IEC C13 avec fusibles
Sorties
- DAC USB
- USB-A 2.0 avec filtrage de l’alimentation et reconstruction de l’intégrité du signal
- I2S/DSD
- Connecteur HDMI à brochage réglable
- AES/EBU
- Connecteur XLR
- S/PDIF coaxiale
- Connecteur BNC
- S/PDIF coaxiale
- Connecteur RCA
- S/PDIF optique
- Connecteur TOSLINK × 2
- Vidéo
- Connecteur HDMI, affiche Volumio sur votre téléviseur (jusqu’en 4K)
- Trigger
- 12 V sur jack 3,5 mm, positif sur la pointe
Écrans
Voyez ce que vous écoutez
Écran principal
L’écran tactile de 12″ offre une nouvelle façon de toucher votre musique, pour une écoute vraiment immersive. Ce superbe écran propose l’interface la plus innovante et la plus riche, pour faire de la musique une expérience sensorielle complète.
Écran du bouton rotatif
L’écran secondaire affiche d’un coup d’œil les informations utiles, en complément du voyant d’état intégré.
Bit-perfect
La vraie haute fidélité ne devrait être ni un défi technique ni une contrainte. Le Rivo Ultra fonctionne avec une version très personnalisée de Volumio OS, qui envoie un audio numérique bit-perfect à votre système.
Écran principal
12 façons de voir votre musique
Vumètres, spectres, la pochette de l’album ou une horloge. Choisissez un écran directement sur l’afficheur ou dans l’application Volumio.
Écrans du logiciel de Rivo Ultra, présentés avec un album fictif.
L’expérience Volumio
Volumio OS à bord. L’app en main.
Le Rivo Ultra fonctionne sous Volumio OS, le lecteur de plus de 800 000 appareils. Vous le pilotez depuis l’application Volumio, gratuite sur iPhone et Android.
Volumio OS à bord
Fonctions Premium intégrées
Votre musique, à votre façon
La qualité ne se limite pas à un son superbe. Volumio Premium inclus. Écoutez avec votre compte TIDAL, Qobuz ou Spotify, plus leurs fonctions Connect et AirPlay. Lisez depuis des disques locaux ou réseau, ou écoutez la radio sur Internet.
Les fonctions Premium appartiennent à ce Rivo Ultra, sans abonnement. Sur un Raspberry Pi ou un PC, les mêmes fonctions sont incluses dans un abonnement Volumio Premium.
Sur l’écran
Pilotez tout depuis l’écran tactile de 12″ en façade.
Sur votre téléviseur
Branchez-vous sur la sortie vidéo HDMI et transformez votre salon en temple de la musique.
En main
Un contrôle total depuis l’application Volumio pour iOS et Android, ou avec la télécommande IR.
Super recherche
Une recherche par IA qui vous aide à découvrir de la musique.
Multiroom
Relie le Rivo Ultra aux autres lecteurs Volumio de la maison.
Roon Ready
Certifié par Roon Labs : le Rivo Ultra fonctionne avec Roon.
Finitions
Tout aluminium ou aluminium et cuir
Le Rivo Ultra existe en deux finitions.
Tout aluminium
Un boîtier en aluminium, dessus compris.
Aluminium et cuir
Un boîtier en aluminium avec un dessus en cuir noir surpiqué.
Comparer
Rivo Ultra ou Rivo Plus
Ce sont deux streamers transport avec les fonctions Premium intégrées. Le Rivo Ultra a la meilleure sortie USB DAC, avec une horloge compensée en température (TCXO) et une alimentation plus propre grâce à l’alimentation linéaire intégrée et à un étage linéaire supplémentaire sur la carte mère. Il ajoute aussi une horloge femto pour les sorties intégrées, des sorties S/PDIF optiques et BNC, un écran tactile de 12 pouces et un emplacement NVMe pour votre musique.
Rivo Ultra
Notre streamer phare
Acheter, Rivo Ultra
Rivo Plus
Le Rivo amélioré
Acheter, Rivo Plus
- Horloge
- Rivo Ultra : Horloge femto, bruit de phase de 54 fs RMS, pour les sorties intégrées ; TCXO pour le hub USB
- Rivo Plus : Horloges MEMS pour le hub USB et l’ASIC de sortie
- Alimentation
- Rivo Ultra : Double alimentation linéaire interne, 115–230 V AC
- Rivo Plus : Externe, 5 V DC / 3 A
- Sortie I2S sur HDMI
- Rivo Ultra : Jusqu’à PCM 768 kHz / 32-bit et DSD1024
- Rivo Plus : Jusqu’à PCM 768 kHz / 32-bit et DSD512
- Sortie S/PDIF coaxiale
- Rivo Ultra : RCA et BNC
- Rivo Plus : RCA
- Sortie S/PDIF optique
- Rivo Ultra : 2 × TOSLINK, jusqu’à PCM 192 kHz / 24-bit et DSD64 via DoP
- Rivo Plus : Non disponible
- Écran et télécommande
- Rivo Ultra : Écran tactile de 12″, un bouton rotatif avec son propre écran, Remoto inclus
- Stockage pour votre musique
- Rivo Ultra : Emplacement NVMe pour un SSD PCIe jusqu’à 16 To, plus des disques USB
- Rivo Plus : Disques USB
- Processeur
- Rivo Ultra : ARM Cortex-A76, quatre cœurs, 2,4 GHz
- Rivo Plus : ARM Cortex-A55, quatre cœurs, 1,9 GHz
- Dimensions et poids
- Rivo Ultra : 44 × 34 × 9 cm, 6 kg
- Rivo Plus : 27 × 15 × 5,2 cm, 1,12 kg
- Finitions
- Rivo Ultra : Tout aluminium, ou aluminium et cuir
- Rivo Plus : Classic, ou la Special Edition en cuir marron
- Sur les deux
- Sortie USB DAC jusqu’à PCM 1536 kHz / 32-bit et DSD1024, multiroom désactivé. AES/EBU et S/PDIF coaxial jusqu’à PCM 192 kHz / 24-bit et DSD64 via DoP. 2 Go DDR4 et 16 Go eMMC. Gigabit Ethernet, Wi-Fi double bande et Bluetooth 5.0. HDMI jusqu’en 4K / 60 fps. Trigger 12 V. Fonctions Premium intégrées.
signifie : non disponible sur ce modèle.
Rivo Ultra
Fiche technique
Audio
- Horloge maître
- Horloge femto au bruit de phase (54 fs RMS) et au jitter ultra-faibles sur les sorties intégrées ; horloge compensée en température (TCXO) sur la sortie USB DAC
- Interface du signal numérique
- Intégration sur mesure d’Amanero768
- Réglage du volume
- Matériel, si le DAC raccordé le prend en charge, sinon logiciel ou aucun
Sorties numériques
- Sortie USB
- Jusqu’à PCM 1536 kHz / 32 bit et DSD1024, multiroom désactivé
- Sortie I2S/DSD sur HDMI
- Jusqu’à PCM 768 kHz / 32 bit et DSD1024, multiroom désactivé
- Jusqu’à PCM 192 kHz / 24 bit et DSD64 via DoP
- Sortie AES/EBU
Logiciel et services
- Formats pris en charge
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 et autres
- Services pris en charge
- AirPlay via Shairport Sync, Spotify Connect, TIDAL et TIDAL Connect, Qobuz et Qobuz Connect, Roon
- UPnP/DLNA
- Renderer compatible OpenHome
- Plugins
Connecteurs
- Sortie DAC USB
- 1 × USB-A 2.0 avec filtrage de l’alimentation et reconstruction de l’intégrité du signal
- USB hôte
- 1 × USB-C, 3 × USB-A 3.0 (clés USB et disques durs/SSD)
- Sortie I2S/DSD
- 1 × HDMI avec brochage configurable
- 1 × RCA, 1 × BNC
- 2 × TOSLINK
- Sortie AES/EBU
- 1 × XLR
- Sortie vidéo
- Recopie de l’application Volumio OS en HDMI, jusqu’en 4K / 60 fps
- Sortie trigger
- 1 × jack 3,5 mm (12 V, positif sur la pointe)
Réseau
- LAN
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2,4 GHz et 5 GHz
- Bluetooth
- 5.0
Processeur et stockage
- CPU
- ARM Cortex-A76, quatre cœurs, 2,4 GHz
- RAM
- 2 Go DDR4
- Stockage interne
- 16 Go eMMC
- Emplacement NVMe pour un SSD PCIe, jusqu’à 16 To
- Horloge temps réel
- Intégrée (nécessite 1 pile CR2032)
Écran et commandes
- Écran
- Écran tactile TFT LCD de 12″ (luminosité réglable)
- Bouton rotatif
- Bouton rotatif avec poussoir et écran intégré (luminosité réglable)
- Télécommande
- Télécommande IR Remoto (incluse)
Alimentation
- Alimentation
- Double alimentation linéaire avec transformateur dédié de qualité audio
- Protection du circuit
- 2 × fusible (1,25 A T), faciles d’accès
- Alimentation
- 115–230 V AC, avec sélecteur de tension manuel
- Entrée d’alimentation
- Cordon secteur (IEC C13)
Dimensions et finitions
- Finitions
- Tout aluminium, ou aluminium avec un dessus en cuir
- Dimensions
- Poids
- 6 kg (13,2 lb)
Dans la boîte
- Rivo Ultra
- Remoto (télécommande)
- Antenne Wi-Fi
- Carte NFC
- Cordon d’alimentation
Avis de propriétaires
L’avis des clients du Rivo Ultra
Rédiger un avis sur la boutique
Avis d’acheteurs vérifiés sur shop.volumio.com, recueillis par REVIEWS.io. Affichés tels quels, dans la langue de leur auteur.
Lo más destacado
- Reproducción bit-perfectCon una versión de Volumio OS optimizada para Rivo Ultra.
- Ruido ultrabajo y jitter reducidoReloj femto con un ruido de fase de 54 fs RMS en las salidas integradas. Reloj compensado en temperatura (TCXO) en la salida USB DAC.
- Amplia selección de salidas digitalesSiete salidas: USB, I2S/DSD por HDMI, AES/EBU, dos S/PDIF coaxiales (una con conector BNC, otra con RCA) y dos S/PDIF ópticas.
- Fuente de alimentación linealDos etapas de regulación lineal independientes, alimentadas por un transformador toroidal de calidad audiófila.
- Ranura de expansión para SSDHasta 16 TB para tu biblioteca musical.
- Pantalla táctil ultrapanorámica12 pulgadas en el frontal, más una pantalla en el mando.
- Interfaz avanzada y personalizableVolumio OS integrado, con Volumio Premium incluido. Compatible con TIDAL, Qobuz, Spotify Connect, AirPlay y Roon Ready.
Rivo Ultra es nuestro streamer insignia, con una versión de Volumio OS optimizada para su diseño.
Hecho en Florencia
Diseñado, ensamblado y probado a mano, en Italia
Rivo Ultra se diseña en Florencia, Italia, donde cada unidad se ensambla y se prueba a mano. Un mismo equipo bajo el mismo techo, que diseña y fabrica tanto el hardware como el software. Cada unidad se prueba a fondo y se embala con cuidado antes de enviártela.
Más sobre Volumio en FlorenciaPor dentro
El streamer más refinado que hemos creado.
Rivo Ultra representa el transporte digital definitivo, la sinergia perfecta entre hardware de calidad de audio y diseño de software. Es la evolución de la mejor tecnología que hemos desarrollado, llevada a nuevas cotas audiófilas.
Salidas
5 formas de llegar a tu DAC
Rivo Ultra es un transporte digital. Envía la señal a tu DAC por USB, I2S/DSD por HDMI, AES/EBU, S/PDIF coaxial o S/PDIF óptica. Un trigger de 12 V enciende y apaga tus otros componentes.
DAC USB
1536kHz
Hasta PCM 1536 kHz / 32-bit y DSD1024 (o DSD256 con el audio multiroom activado). La salida USB DAC cuenta con filtrado de alimentación y reconstrucción de la integridad de la señal. Con DAC compatibles, el volumen se ajusta desde Rivo Ultra.
I2S/DSD por HDMI
768kHz
Hasta PCM 768 kHz / 32-bit y DSD1024 (o DSD256 con el audio multiroom activado). La asignación de pines del conector HDMI es configurable para adaptar Rivo Ultra a tu DAC.
AES/EBU
192kHz
Hasta PCM 192 kHz / 24-bit y DSD64 (DoP), con una salida digital balanceada.
S/PDIF coaxial
192kHz
Hasta PCM 192 kHz / 24-bit y DSD64 (DoP), por conectores RCA y BNC para la máxima flexibilidad.
S/PDIF óptica
192kHz
Hasta PCM 192 kHz / 24-bit y DSD64 (DoP), con 2 salidas por conectores TOSLINK.
Conexiones
De tu red a tu DAC
Reproduce por streaming con Gigabit Ethernet o wifi de doble banda, o desde el SSD interno y unidades USB. En la parte trasera, I2S/DSD y vídeo tienen cada uno su propio conector HDMI.
Entradas
- Ethernet
- Wi-Fi
- 802.11a/b/g/n/ac, 2,4 y 5 GHz
- Bluetooth
- 5.0
- Host USB-A
- Memorias USB, HDD/SSD, unidad óptica USB
- NVMe
- SSD PCIe de hasta 16 TB
- Alimentación
- 115–230 V AC en toma IEC C13 con fusibles
Salidas
- DAC USB
- USB-A 2.0 con filtrado de alimentación y reconstrucción de la integridad de la señal
- I2S/DSD
- Conector HDMI con asignación de pines ajustable
- AES/EBU
- Conector XLR
- S/PDIF coaxial
- Conector BNC
- S/PDIF coaxial
- Conector RCA
- S/PDIF óptica
- Conector TOSLINK × 2
- Vídeo
- Conector HDMI, muestra Volumio en tu televisor (hasta 4K)
- Trigger
- 12 V en una toma de 3,5 mm, con el positivo en la punta
Pantallas
Mira lo que escuchas
Pantalla principal
La pantalla táctil de 12″ es una nueva forma de tocar tu música, para una escucha realmente envolvente. Esta espléndida pantalla ofrece la interfaz más innovadora y gratificante, para que la música sea una experiencia para todos los sentidos.
Pantalla del mando
La pantalla secundaria muestra de un vistazo la información útil, como complemento del LED de estado integrado.
Bit-perfect
La verdadera alta fidelidad no debería ser un reto técnico ni una limitación. Rivo Ultra funciona con una versión muy personalizada de Volumio OS que envía audio digital bit-perfect a tu equipo.
Pantalla principal
12 formas de ver tu música
Vúmetros, espectros, la portada del álbum o un reloj. Elige una pantalla en el propio display o en la app de Volumio.
Pantallas del software de Rivo Ultra, mostradas con un álbum ficticio.
La experiencia Volumio
Volumio OS dentro. La app en tu mano.
Rivo Ultra funciona con Volumio OS, el reproductor que mueve más de 800.000 dispositivos. Se controla desde la app de Volumio, gratuita para iPhone y Android.
Funciones Premium incluidas
Tu música, a tu manera
La calidad va más allá de un sonido excelente. Volumio Premium incluido. Escucha con tu cuenta de TIDAL, Qobuz o Spotify, además de sus funciones Connect y AirPlay. Reproduce desde unidades locales o de red, o escucha la radio por internet.
Las funciones Premium vienen con este Rivo Ultra, sin suscripción. En una Raspberry Pi o un PC, las mismas funciones se incluyen en una suscripción a Volumio Premium.
En la pantalla
Controla todo desde la pantalla táctil de 12″ del panel frontal.
En tu televisor
Conéctate a través de la salida de vídeo HDMI y convierte tu salón en un templo de la música.
En tu mano
Control total desde la app de Volumio para iOS y Android, o con el mando IR.
Súper búsqueda
Una búsqueda con IA que te ayuda a descubrir música.
Multiroom
Conecta Rivo Ultra con los demás reproductores Volumio de tu casa.
Roon Ready
Certificado por Roon Labs, para que Rivo Ultra funcione con Roon.
Acabados
Todo aluminio o aluminio y piel
Rivo Ultra se presenta en dos acabados.
Todo aluminio
Una caja de aluminio, con la tapa incluida.
Aluminio y piel
Una caja de aluminio con la tapa de piel negra cosida.
Comparativa
Los dos son streamer transport con las funciones Premium incluidas. Rivo Ultra tiene la mejor salida USB DAC, con un reloj compensado en temperatura (TCXO) y una alimentación más limpia gracias a la fuente lineal integrada y a una etapa lineal adicional en la placa base. Además añade un reloj femto para las salidas integradas, salidas S/PDIF ópticas y BNC, una pantalla táctil de 12 pulgadas y una ranura NVMe para tu música.
Rivo Ultra
Nuestro streamer insignia
Comprar, Rivo Ultra
Rivo Plus
El Rivo mejorado
Comprar, Rivo Plus
- Reloj
- Rivo Ultra: Reloj femto, ruido de fase de 54 fs RMS, para las salidas integradas; TCXO para el hub USB
- Rivo Plus: Relojes MEMS para el hub USB y el ASIC de salida
- Rivo Ultra: Fuente lineal doble interna, 115–230 V AC
- Rivo Plus: Externa, 5 V DC / 3 A
- Salida I2S por HDMI
- Rivo Ultra: Hasta PCM 768 kHz / 32-bit y DSD1024
- Rivo Plus: Hasta PCM 768 kHz / 32-bit y DSD512
- Salida S/PDIF coaxial
- Rivo Ultra: RCA y BNC
- Rivo Plus: RCA
- Salida S/PDIF óptica
- Rivo Ultra: 2 × TOSLINK, hasta PCM 192 kHz / 24-bit y DSD64 mediante DoP
- Rivo Plus: No disponible
- Pantalla y mando a distancia
- Rivo Ultra: Pantalla táctil de 12″, un mando con su propia pantalla, Remoto incluido
- Almacenamiento para tu música
- Rivo Ultra: Ranura NVMe para un SSD PCIe de hasta 16 TB, más unidades USB
- Rivo Plus: Unidades USB
- Procesador
- Rivo Ultra: ARM Cortex-A76, cuatro núcleos, 2,4 GHz
- Rivo Plus: ARM Cortex-A55, cuatro núcleos, 1,9 GHz
- Tamaño y peso
- Acabados
- Rivo Ultra: Todo aluminio, o aluminio y piel
- Rivo Plus: Classic, o la Special Edition en piel marrón
- En ambos
- Salida USB DAC hasta PCM 1536 kHz / 32-bit y DSD1024, con el multiroom desactivado. AES/EBU y S/PDIF coaxial hasta PCM 192 kHz / 24-bit y DSD64 mediante DoP. 2 GB DDR4 y 16 GB eMMC. Gigabit Ethernet, wifi de doble banda y Bluetooth 5.0. HDMI hasta 4K / 60 fps. Trigger de 12 V. Funciones Premium incluidas.
significa que no está disponible en ese modelo.
Rivo Ultra
Especificaciones
Audio
- Reloj maestro
- Reloj femto con ruido de fase (54 fs RMS) y jitter ultrabajos en las salidas integradas; reloj compensado en temperatura (TCXO) en la salida USB DAC
- Interfaz de señal digital
- Integración personalizada de Amanero768
- Ajuste de volumen
- Por hardware, si el DAC conectado lo admite; si no, por software o ninguno
Salidas digitales
- Salida USB
- Hasta PCM 1536 kHz / 32 bit y DSD1024, con el multiroom desactivado
- Salida I2S/DSD por HDMI
- Hasta PCM 768 kHz / 32 bit y DSD1024, con el multiroom desactivado
- Hasta PCM 192 kHz / 24 bit y DSD64 mediante DoP
- Salida AES/EBU
Software y servicios
- Formatos admitidos
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 y otros
- Servicios compatibles
- AirPlay mediante Shairport Sync, Spotify Connect, TIDAL y TIDAL Connect, Qobuz y Qobuz Connect, Roon
- UPnP/DLNA
- Renderizador compatible con OpenHome
- Plugins
Conectores
- Salida DAC USB
- 1 × USB-A 2.0 con filtrado de alimentación y reconstrucción de la integridad de la señal
- Host USB
- 1 × USB-C, 3 × USB-A 3.0 (memorias USB y HDD/SSD)
- Salida I2S/DSD
- 1 × HDMI con asignación de pines configurable
- 1 × RCA, 1 × BNC
- 2 × TOSLINK
- Salida AES/EBU
- 1 × XLR
- Salida de vídeo
- Duplicado de la app de Volumio OS por HDMI hasta 4K / 60 fps
- Salida de trigger
- 1 × toma de 3,5 mm (12 V, positivo en la punta)
Red
- LAN
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2,4 GHz y 5 GHz
- Bluetooth
- 5.0
Procesador y almacenamiento
- CPU
- ARM Cortex-A76, cuatro núcleos a 2,4 GHz
- RAM
- 2 GB DDR4
- Almacenamiento interno
- 16 GB eMMC
- Ranura NVMe para un SSD PCIe, hasta 16 TB
- Reloj en tiempo real
- Integrado (necesita 1 pila CR2032)
Pantalla y controles
- Pantalla
- Pantalla táctil TFT LCD de 12″ (brillo ajustable)
- Mando
- Mando giratorio con pulsador y pantalla propia (brillo ajustable)
- Mando a distancia
- Mando a distancia IR Remoto (incluido)
Alimentación
- Fuente de alimentación lineal doble con transformador dedicado de calidad de audio
- Protección del circuito
- 2 × fusible (1,25 A T), de fácil acceso
- Alimentación
- 115–230 V AC, con selector de tensión manual
- Entrada de alimentación
- Cable de alimentación AC (IEC C13)
Tamaño y acabados
- Acabados
- Todo aluminio, o aluminio con tapa de piel
- Dimensiones
- Peso
- 6 kg (13,2 lb)
En la caja
- Rivo Ultra
- Remoto (mando a distancia)
- Antena wifi
- Tarjeta NFC
Reseñas de propietarios
Qué opinan de Rivo Ultra
Escribir una reseña en la tienda
Reseñas de compradores verificados en shop.volumio.com, recopiladas por REVIEWS.io. Se muestran tal como se escribieron, en el idioma de cada autor.
Reviews
Primo V3
AU$1,599.00 -
Lineo5 Duo
AU$857.80 -
Remoto
AU$69.00 -
Primo Plus
Was: AU$2,499.00Now: AU$1,679.00 -
Preciso
Was: AU$1,399.00Now: AU$1,119.00 -
Rivo Plus
AU$2,375.87 -
Lineo5
AU$849.00 -
Motivo
AU$3,199.00 -
Integro
AU$1,499.00 -
Primo
Was: AU$1,399.00Now: AU$1,039.00
