The highlights
- Volumio OSinside: TIDAL, Qobuz, Spotify Connect, AirPlay and Roon Ready, with every Premium feature built in
- 384kHzPCM at 32-bit, from the built-in DAC
- 8+ NOSDAC filters, or none at all
- 8levelsof output to match your amplifier, up to 6.3 Vrms balanced
- Preampmode, hardware volume set in the app: connect straight to a power amp
- 4KVolumio on your TV over HDMI, at 60 fps
Primo V3 is designed and made in Florence.
Made in Florence
Assembled by hand, in Italy
Primo V3 is designed in Florence and assembled there by hand, by the team that also writes its software. Each unit is checked before it leaves the lab.
More about Volumio in FlorenceLook inside
Engineered for sound
Primo V3 is a complete redesign of the original Primo. A linear power supply stage and a high-precision clock keep noise and jitter low, and the layout keeps every current path short. Along the edge sits a hidden nod to Florence. Pick a part to find it on the board.
Sound
Match it to your system
Eight filters, or none
Pick one of eight DAC filters, with Minimum Phase as the default. Or switch on NOS mode for conversion without oversampling.
Eight output levels
Set the level to suit your amplifier or active speakers. With the volume set in the app, Primo V3 also works as a preamp, straight into a power amp.
Connections
Network in. Analog out.
Stream over Gigabit Ethernet or dual-band Wi-Fi. Then send the signal out balanced or unbalanced, or to a USB DAC.
In
- Ethernet
- Gigabit, 10/100/1000
- Wi-Fi
- 802.11a/b/g/n/ac, 2.4 and 5 GHz
- Power
- 5 V DC / 3 A, on a 5.5 × 2.1 mm barrel jack
Out
- Analog
- Built-in DAC, up to PCM 384 kHz / 32-bit
- Balanced
- XLR, 1.00 to 6.30 Vrms in 8 levels
- Unbalanced
- RCA, 0.50 to 3.15 Vrms in 8 levels
- USB-A × 2
- To a USB DAC, up to PCM 1536 kHz / 32-bit and DSD1024, with multiroom off
- HDMI
- Mirrors the Volumio app on your TV, up to 4K at 60 fps
The Volumio experience
Primo V3 runs Volumio OS, the player behind 800,000+ devices. You play it from the Volumio app, free on iPhone and Android.
Volumio OS inside
Premium features built in
All your music. One platform.
Primo V3 has every Premium feature built in. TIDAL, Qobuz and Spotify sit next to internet radio such as Radio Paradise and TuneIn, in one place. TIDAL Connect, Qobuz Connect, Spotify Connect and AirPlay work too.
They belong to this Primo, with no subscription. On a Raspberry Pi or a PC, the same features come with a Volumio Premium subscription.
On your TV
Connect HDMI and browse your music on the big screen, in up to 4K at 60 fps.
In your hand
Browse, play and control it all from the Volumio app, in lossless and high resolution.
Compare
Primo V3 or Primo V2
Both are streamer DACs with the Premium features built in, and both measure 27 × 15 × 5.2 cm. Primo V3 moves to the ES9039Q2M DAC, plays up to PCM 384 kHz / 32-bit and adds adjustable outputs and NOS mode. Primo V2 keeps an S/PDIF coaxial output and comes in two finishes.
Primo V3
Latest generation
Buy, Primo V3
Primo V2
Classic or Florence Edition. iF Design Award 2024.
Buy, Primo V2Discover Primo V2
- DAC
- Primo V3: ESS ES9039Q2M
- Primo V2: ESS ES9038Q2M
- DAC resolution
- Primo V3: Up to PCM 384 kHz / 32-bit
- Primo V2: Up to PCM 192 kHz / 24-bit
- DAC filters
- Primo V3: 8, Minimum Phase by default
- Primo V2: 7
- NOS mode
- Primo V3: Available
- Primo V2: Not available
- Balanced XLR output
- Primo V3: 8 selectable levels, 1.00 to 6.30 Vrms
- Primo V2: 4 Vrms, fixed
- Unbalanced RCA output
- Primo V3: 8 selectable levels, 0.50 to 3.15 Vrms
- Primo V2: 2 Vrms, fixed
- S/PDIF coaxial output
- Primo V3: Not available
- Processor
- Primo V3: ARM Cortex-A72, quad-core, 1.5 GHz
- Primo V2: ARM Cortex-A55, quad-core, 1.9 GHz
- USB-A ports
- Primo V3: 2 × USB 2.0, 0.56 A and 1.33 A
- Primo V2: 1 × USB 3.0 and 1 × USB 2.0
- On both
- 2 GB DDR4 memory and 16 GB eMMC storage. Gigabit Ethernet, dual-band Wi-Fi and Bluetooth 5.0. HDMI up to 4K / 60 fps. Preamp mode, straight into a power amp. 5 V / 3 A power. 27 × 15 × 5.2 cm and 1.12 kg. Premium features built in.
Primo V3
Tech specs
Primo V3 audio specifications
- DAC
- ESS Sabre ES9039Q2M
- DAC filters
- 8 digital filters for fine tuning
- Supported resolution
- Up to PCM 384 kHz / 32 bit
- NOS mode
- Switchable ON/OFF
- Master clock
- Ultra-low phase noise
- Preamp mode
- Hardware, volume set from the app
- Power supply
- Integrated linear power supply stage
- USB output
- Up to PCM 1536 kHz / 32 bit and DSD1024, with multiroom off
- Analog balanced output
- 1.00, 1.55, 2.00, 3.00, 4.00, 5.00, 6.00, 6.30 (Vrms)
- Analog unbalanced output
- 0.50, 0.775, 1.00, 1.50, 2.00, 2.50, 3.00, 3.15 (Vrms)
- Analog output impedance
- ≈140 Ω
- Supported formats
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 and others
- Supported services
- AirPlay via Shairport Sync, Spotify Connect, TIDAL and TIDAL Connect, Qobuz and Qobuz Connect, Roon
- UPnP/DLNA
- Renderer with OpenHome support
- Plugins
- YouTube, Squeezelite, Radio Paradise, Podcasts, Pandora, Fusion DSP, SoundCloud, Mixcloud
Primo V3 hardware specifications
- USB
- 2 × USB-A 2.0 (5 V / 0.56 A; 5 V / 1.33 A)
- 1 × XLR (stereo)
- 1 × RCA (stereo)
- Video output
- Volumio OS app mirroring over HDMI up to 4K / 60 fps
- LAN
- Gigabit 10/100/1000 Mbps
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2.4 GHz and 5 GHz
- Bluetooth
- 5.0
- CPU
- ARM Cortex-A72, Quad Core 1.5 GHz
- RAM
- 2 GB DDR4
- Internal storage
- 16 GB eMMC
- Power
- 5 V DC / 3 A
- Power input
- Barrel jack 5.5 × 2.1 mm (positive polarity)
- Dimensions
- 27 × 15 × 5.2 cm (10.6 × 5.9 × 2.0 in)
- Weight
- 1.12 kg (2.47 lb)
- Box dimensions
- 31.5 × 19.7 × 11.6 cm (12.4 × 7.8 × 4.6 in)
- Box weight
- 1.96 kg (4.32 lb)
In the box
- Volumio Primo V3
- 5 V / 3 A power supply
- NFC and QR code information card
Owner reviews
What Primo V3 owners say
Die Highlights
- Volumio OSan Bord: TIDAL, Qobuz, Spotify Connect, AirPlay und Roon Ready, mit allen Premium-Funktionen integriert
- 384kHzPCM mit 32 Bit, vom integrierten DAC
- 8+ NOSDAC-Filter, oder gar keiner
- 8StufenAusgangspegel passend zu Ihrem Verstärker, bis 6,3 Vrms symmetrisch
- VorverstärkerModus mit Hardware-Lautstärke per App: direkt an einen Endverstärker anschließen
- 4KVolumio auf Ihrem Fernseher über HDMI, mit 60 fps
Primo V3 wird in Florenz entworfen und gefertigt.
Hergestellt in Florenz
Von Hand montiert, in Italien
Primo V3 wird in Florenz entworfen und dort von Hand montiert, von demselben Team, das auch seine Software schreibt. Jedes Gerät wird geprüft, bevor es das Labor verlässt.
Mehr über Volumio in FlorenzEin Blick ins Innere
Entwickelt für Klang
Primo V3 ist eine komplette Neuentwicklung des ursprünglichen Primo. Eine lineare Netzteilstufe und ein hochpräziser Taktgeber halten Rauschen und Jitter gering, und das Layout hält alle Strompfade kurz. Entlang der Kante versteckt sich eine Hommage an Florenz. Wählen Sie ein Bauteil, um es auf der Platine zu finden.
Klang
Passend zu Ihrer Anlage
Acht Filter oder keiner
Wählen Sie einen von acht DAC-Filtern, standardmäßig Minimum Phase. Oder schalten Sie den NOS-Modus ein, für eine Wandlung ohne Oversampling.
Acht Ausgangspegel
Stellen Sie den Pegel passend zu Ihrem Verstärker oder Ihren Aktivlautsprechern ein. Mit der Lautstärkeregelung in der App arbeitet Primo V3 auch als Vorverstärker, direkt an einem Endverstärker.
Anschlüsse
Netzwerk rein. Analog raus.
Streamen Sie über Gigabit-Ethernet oder Dualband-WLAN. Dann geben Sie das Signal symmetrisch oder unsymmetrisch aus, oder an einen USB-DAC.
Eingänge
- Ethernet
- WLAN
- 802.11a/b/g/n/ac, 2,4 und 5 GHz
- Stromversorgung
- 5 V DC / 3 A, über Hohlbuchse 5,5 × 2,1 mm
Ausgänge
- Analog
- Integrierter DAC, bis zu PCM 384 kHz / 32 Bit
- Symmetrisch
- XLR, 1,00 bis 6,30 Vrms in 8 Stufen
- Unsymmetrisch
- RCA, 0,50 bis 3,15 Vrms in 8 Stufen
- USB-A × 2
- An einen USB-DAC, bis zu PCM 1536 kHz / 32 Bit und DSD1024, bei deaktiviertem Multiroom
- HDMI
- Spiegelt die Volumio-App auf Ihren Fernseher, bis zu 4K mit 60 fps
Das Volumio-Erlebnis
Volumio OS an Bord. Die App in der Hand.
Primo V3 läuft mit Volumio OS, dem Player hinter 800.000+ Geräten. Sie bedienen ihn mit der Volumio-App, kostenlos für iPhone und Android.
Volumio OS an Bord
Ihre ganze Musik. Eine Plattform.
In Primo V3 sind alle Premium-Funktionen integriert. TIDAL, Qobuz und Spotify stehen neben Internetradio wie Radio Paradise und TuneIn, alles an einem Ort. TIDAL Connect, Qobuz Connect, Spotify Connect und AirPlay funktionieren ebenfalls.
Sie gehören zu diesem Primo, ohne Abo. Auf einem Raspberry Pi oder PC gibt es dieselben Funktionen mit einem Volumio Premium-Abo.
Auf Ihrem Fernseher
Schließen Sie HDMI an und durchstöbern Sie Ihre Musik auf dem großen Bildschirm, in bis zu 4K mit 60 fps.
In Ihrer Hand
Mit der Volumio-App alles durchstöbern, abspielen und steuern, verlustfrei und in hoher Auflösung.
Vergleichen
Primo V3 oder Primo V2
Beide sind Streamer-DACs mit integrierten Premium-Funktionen, und beide messen 27 × 15 × 5,2 cm. Primo V3 wechselt zum DAC ES9039Q2M, spielt bis zu PCM 384 kHz / 32 Bit und bietet zusätzlich einstellbare Ausgänge und den NOS-Modus. Primo V2 behält einen koaxialen S/PDIF-Ausgang und ist in zwei Ausführungen erhältlich.
Primo V3
Neueste Generation
Kaufen, Primo V3
Primo V2
Classic oder Florence Edition. iF Design Award 2024.
Kaufen, Primo V2Primo V2 entdecken
- DAC
- DAC-Auflösung
- Primo V3: Bis zu PCM 384 kHz / 32 Bit
- Primo V2: Bis zu PCM 192 kHz / 24 Bit
- DAC-Filter
- Primo V3: 8, standardmäßig Minimum Phase
- Primo V2: 7
- NOS-Modus
- Primo V3: Verfügbar
- Primo V2: Nicht verfügbar
- Symmetrischer XLR-Ausgang
- Primo V3: 8 wählbare Stufen, 1,00 bis 6,30 Vrms
- Primo V2: 4 Vrms, fest
- Unsymmetrischer RCA-Ausgang
- Primo V3: 8 wählbare Stufen, 0,50 bis 3,15 Vrms
- Primo V2: 2 Vrms, fest
- Koaxialer S/PDIF-Ausgang
- Primo V3: Nicht verfügbar
- Prozessor
- Primo V3: ARM Cortex-A72, Quad-Core, 1,5 GHz
- Primo V2: ARM Cortex-A55, Quad-Core, 1,9 GHz
- USB-A-Anschlüsse
- Primo V3: 2 × USB 2.0, 0,56 A und 1,33 A
- Primo V2: 1 × USB 3.0 und 1 × USB 2.0
- Bei beiden
- 2 GB DDR4-Arbeitsspeicher und 16 GB eMMC-Speicher. Gigabit-Ethernet, Dualband-WLAN und Bluetooth 5.0. HDMI bis zu 4K / 60 fps. Vorverstärkermodus, direkt an einen Endverstärker. Stromversorgung 5 V / 3 A. 27 × 15 × 5,2 cm und 1,12 kg. Premium-Funktionen integriert.
Primo V3
Technische Daten
Audio-Spezifikationen von Primo V3
- DAC
- DAC-Filter
- 8 Digitalfilter zur Feinabstimmung
- Unterstützte Auflösung
- Bis zu PCM 384 kHz / 32 Bit
- NOS-Modus
- Ein- und ausschaltbar
- Master-Taktgeber
- Extrem geringes Phasenrauschen
- Vorverstärkermodus
- Hardware, Lautstärke per App
- Netzteil
- Integrierte lineare Netzteilstufe
- USB-Ausgang
- Bis zu PCM 1536 kHz / 32 Bit und DSD1024, bei deaktiviertem Multiroom
- Analoger symmetrischer Ausgang
- 1,00; 1,55; 2,00; 3,00; 4,00; 5,00; 6,00; 6,30 (Vrms)
- Analoger unsymmetrischer Ausgang
- 0,50; 0,775; 1,00; 1,50; 2,00; 2,50; 3,00; 3,15 (Vrms)
- Analoge Ausgangsimpedanz
- ≈140 Ω
- Unterstützte Formate
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 und weitere
- Unterstützte Dienste
- AirPlay über Shairport Sync, Spotify Connect, TIDAL und TIDAL Connect, Qobuz und Qobuz Connect, Roon
- UPnP/DLNA
- Renderer mit OpenHome-Unterstützung
- Plugins
Hardware-Spezifikationen von Primo V3
- USB
- 2 × USB-A 2.0 (5 V / 0,56 A; 5 V / 1,33 A)
- 1 × XLR (Stereo)
- 1 × RCA (Stereo)
- Videoausgang
- Spiegelung der Volumio-App über HDMI, bis zu 4K / 60 fps
- LAN
- WLAN
- WLAN 802.11a/b/g/n/ac, 2,4 GHz und 5 GHz
- Bluetooth
- 5.0
- CPU
- ARM Cortex-A72, Quad-Core 1,5 GHz
- RAM
- 2 GB DDR4
- Interner Speicher
- 16 GB eMMC
- Stromversorgung
- 5 V DC / 3 A
- Stromeingang
- Hohlbuchse 5,5 × 2,1 mm (Pluspol innen)
- Abmessungen
- 27 × 15 × 5,2 cm (10,6 × 5,9 × 2,0 in)
- Gewicht
- 1,12 kg (2,47 lb)
- Verpackungsmaße
- 31,5 × 19,7 × 11,6 cm (12,4 × 7,8 × 4,6 in)
- Versandgewicht
- 1,96 kg (4,32 lb)
Lieferumfang
- Volumio Primo V3
- Netzteil 5 V / 3 A
- Infokarte mit NFC und QR-Code
Kundenbewertungen
Was Besitzer von Primo V3 sagen
Bewertungen verifizierter Käufer auf shop.volumio.com, gesammelt von REVIEWS.io. Unverändert wiedergegeben, in der Sprache der Verfasser.
In evidenza
- Volumio OSa bordo: TIDAL, Qobuz, Spotify Connect, AirPlay e Roon Ready, con tutte le funzioni Premium incluse
- 384kHzPCM a 32-bit, dal DAC integrato
- 8+ NOSfiltri DAC, o nessuno
- 8livellidi uscita da adattare al tuo amplificatore, fino a 6,3 Vrms bilanciati
- Preampliintegrato, con volume hardware regolato dall'app: collegalo direttamente a un finale di potenza
- 4KVolumio sulla tua TV via HDMI, a 60 fps
Primo V3 è progettato e prodotto a Firenze.
Realizzato a Firenze
Assemblato a mano, in Italia
Primo V3 è progettato a Firenze e assemblato lì a mano, dallo stesso team che ne scrive il software. Ogni unità viene controllata prima di lasciare il laboratorio.
Scopri di più su Volumio a FirenzeUno sguardo all'interno
Progettato per il suono
Primo V3 è una riprogettazione completa del Primo originale. Uno stadio di alimentazione lineare e un clock ad alta precisione mantengono bassi rumore e jitter, e il layout tiene corti tutti i percorsi di corrente. Lungo il bordo si nasconde un omaggio a Firenze. Scegli un componente per trovarlo sulla scheda.
Suono
Su misura per il tuo impianto
Otto filtri, o nessuno
Scegli uno degli otto filtri DAC, con Minimum Phase come predefinito. Oppure attiva la modalità NOS per una conversione senza oversampling.
Otto livelli di uscita
Regola il livello in base al tuo amplificatore o ai tuoi diffusori attivi. Con il volume regolato dall'app, Primo V3 funziona anche da preamplificatore, collegato direttamente a un finale di potenza.
Connessioni
In ingresso, la rete. In uscita, l'analogico.
Ascolta in streaming via Gigabit Ethernet o Wi-Fi dual band, poi manda il segnale in uscita, bilanciato o sbilanciato, oppure a un DAC USB.
Ingressi
- Ethernet
- Wi-Fi
- 802.11a/b/g/n/ac, 2,4 e 5 GHz
- Alimentazione
- 5 V DC / 3 A, su spinotto DC da 5,5 × 2,1 mm
Uscite
- Analogica
- DAC integrato, fino a PCM 384 kHz / 32-bit
- Bilanciata
- XLR, da 1,00 a 6,30 Vrms in 8 livelli
- Sbilanciata
- RCA, da 0,50 a 3,15 Vrms in 8 livelli
- USB-A × 2
- Verso un DAC USB, fino a PCM 1536 kHz / 32-bit e DSD1024, con multiroom disattivato
- HDMI
- Mostra l'app Volumio sulla tua TV, fino a 4K a 60 fps
L'esperienza Volumio
Volumio OS a bordo. L'app nelle tue mani.
Primo V3 usa Volumio OS, il lettore che fa suonare oltre 800.000 dispositivi. Lo controlli dall'app Volumio, gratuita per iPhone e Android.
Volumio OS a bordo
Funzioni Premium incluse
La tua musica. Una piattaforma.
Primo V3 include tutte le funzioni Premium. TIDAL, Qobuz e Spotify stanno accanto alla radio via internet, come Radio Paradise e TuneIn, in un unico posto. Funzionano anche TIDAL Connect, Qobuz Connect, Spotify Connect e AirPlay.
Restano legate a questo Primo, senza abbonamento. Su un Raspberry Pi o un PC, le stesse funzioni richiedono un abbonamento a Volumio Premium.
Sulla tua TV
Collega l'HDMI e sfoglia la tua musica sul grande schermo, fino a 4K a 60 fps.
Nelle tue mani
Sfoglia, ascolta e controlla tutto dall'app Volumio, in lossless e in alta risoluzione.
Confronta
Primo V3 o Primo V2
Entrambi sono streamer DAC con le funzioni Premium incluse, ed entrambi misurano 27 × 15 × 5,2 cm. Primo V3 passa al DAC ES9039Q2M, riproduce fino a PCM 384 kHz / 32-bit e aggiunge uscite regolabili e la modalità NOS. Primo V2 mantiene un'uscita S/PDIF coassiale ed è disponibile in due finiture.
Primo V3
Ultima generazione
Acquista, Primo V3
Primo V2
Classic o Florence Edition. iF Design Award 2024.
Acquista, Primo V2Scopri Primo V2
- DAC
- Risoluzione del DAC
- Primo V3: Fino a PCM 384 kHz / 32-bit
- Primo V2: Fino a PCM 192 kHz / 24-bit
- Filtri DAC
- Primo V3: 8, Minimum Phase come predefinito
- Primo V2: 7
- Modalità NOS
- Primo V3: Disponibile
- Primo V2: Non disponibile
- Uscita bilanciata XLR
- Primo V3: 8 livelli selezionabili, da 1,00 a 6,30 Vrms
- Primo V2: 4 Vrms, fissa
- Uscita sbilanciata RCA
- Primo V3: 8 livelli selezionabili, da 0,50 a 3,15 Vrms
- Primo V2: 2 Vrms, fissa
- Uscita S/PDIF coassiale
- Primo V3: Non disponibile
- Processore
- Primo V3: ARM Cortex-A72, quad-core, 1,5 GHz
- Primo V2: ARM Cortex-A55, quad-core, 1,9 GHz
- Porte USB-A
- Primo V3: 2 × USB 2.0, 0,56 A e 1,33 A
- Primo V2: 1 × USB 3.0 e 1 × USB 2.0
- In comune
- 2 GB di memoria DDR4 e 16 GB di archiviazione eMMC. Gigabit Ethernet, Wi-Fi dual band e Bluetooth 5.0. HDMI fino a 4K / 60 fps. Modalità preamplificatore, collegato direttamente a un finale di potenza. Alimentazione 5 V / 3 A. 27 × 15 × 5,2 cm e 1,12 kg. Funzioni Premium incluse.
Primo V3
Specifiche
Specifiche audio di Primo V3
- DAC
- Filtri DAC
- 8 filtri digitali per la messa a punto
- Risoluzione supportata
- Fino a PCM 384 kHz / 32 bit
- Modalità NOS
- Attivabile e disattivabile
- Master clock
- Rumore di fase ultra basso
- Modalità preamplificatore
- Hardware, volume regolato dall'app
- Alimentatore
- Stadio di alimentazione lineare integrato
- Uscita USB
- Fino a PCM 1536 kHz / 32 bit e DSD1024, con multiroom disattivato
- Uscita analogica bilanciata
- Uscita analogica sbilanciata
- Impedenza di uscita analogica
- ≈140 Ω
- Formati supportati
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 e altri
- Servizi supportati
- AirPlay via Shairport Sync, Spotify Connect, TIDAL e TIDAL Connect, Qobuz e Qobuz Connect, Roon
- UPnP/DLNA
- Renderer con supporto OpenHome
- Plugin
- YouTube, Squeezelite, Radio Paradise, Podcast, Pandora, Fusion DSP, SoundCloud, Mixcloud
Specifiche hardware di Primo V3
- USB
- 1 × XLR (stereo)
- 1 × RCA (stereo)
- Uscita video
- Mirroring dell'app Volumio OS via HDMI fino a 4K / 60 fps
- LAN
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2,4 GHz e 5 GHz
- Bluetooth
- 5.0
- CPU
- ARM Cortex-A72, Quad Core 1,5 GHz
- RAM
- 2 GB DDR4
- Archiviazione interna
- 16 GB eMMC
- Alimentazione
- 5 V DC / 3 A
- Ingresso di alimentazione
- Spinotto DC 5,5 × 2,1 mm (positivo al centro)
- Dimensioni
- Peso
- 1,12 kg (2,47 lb)
- Dimensioni imballo
- Peso con imballo
- 1,96 kg (4,32 lb)
Nella confezione
- Volumio Primo V3
- Alimentatore 5 V / 3 A
- Scheda informativa con NFC e codice QR
Recensioni dei proprietari
Il parere di chi ha Primo V3
Scrivi una recensione nello shop
Recensioni di acquirenti verificati su shop.volumio.com, raccolte da REVIEWS.io. Mostrate così come sono state scritte, nella lingua dell'autore.
Les points forts
- Volumio OSà bord : TIDAL, Qobuz, Spotify Connect, AirPlay et Roon Ready, avec toutes les fonctions Premium incluses
- 384kHzPCM en 32-bit, depuis le DAC intégré
- 8+ NOSfiltres du DAC, ou aucun
- 8niveauxde sortie adaptés à votre amplificateur, jusqu’à 6,3 Vrms en symétrique
- Préampliintégré, volume matériel réglé dans l’application : à relier directement à un amplificateur de puissance
- 4KVolumio sur votre téléviseur en HDMI, à 60 fps
Le Primo V3 est conçu et fabriqué à Florence.
Fabriqué à Florence
Assemblé à la main, en Italie
Le Primo V3 est conçu à Florence et y est assemblé à la main, par l’équipe qui développe aussi son logiciel. Chaque exemplaire est contrôlé avant de quitter l’atelier.
En savoir plus sur Volumio à FlorenceVue intérieure
Conçu pour le son
Le Primo V3 est une refonte complète du Primo d’origine. Un étage d’alimentation linéaire et une horloge de haute précision maintiennent le bruit et la gigue à un niveau bas, et l’implantation raccourcit chaque chemin de courant. Le long du bord se cache un clin d’œil à Florence. Choisissez un composant pour le situer sur la carte.
Son
Adaptez-le à votre système
Huit filtres, ou aucun
Choisissez l’un des huit filtres du DAC, Minimum Phase par défaut. Ou activez le mode NOS pour une conversion sans suréchantillonnage.
Huit niveaux de sortie
Réglez le niveau selon votre amplificateur ou vos enceintes actives. Avec le volume réglé dans l’application, le Primo V3 sert aussi de préamplificateur, directement relié à un amplificateur de puissance.
Connectique
Réseau en entrée. Analogique en sortie.
Diffusez en Gigabit Ethernet ou en Wi-Fi double bande. Puis envoyez le signal en symétrique ou en asymétrique, ou vers un DAC USB.
Entrées
- Ethernet
- Wi-Fi
- 802.11a/b/g/n/ac, 2,4 et 5 GHz
- Alimentation
- 5 V DC / 3 A, sur connecteur DC 5,5 × 2,1 mm
Sorties
- Analogique
- DAC intégré, jusqu’à PCM 384 kHz / 32-bit
- Symétrique
- XLR, de 1,00 à 6,30 Vrms en 8 niveaux
- Asymétrique
- RCA, de 0,50 à 3,15 Vrms en 8 niveaux
- USB-A × 2
- Vers un DAC USB, jusqu’à PCM 1536 kHz / 32-bit et DSD1024, multiroom désactivé
- HDMI
- Recopie l’application Volumio sur votre téléviseur, jusqu’en 4K à 60 fps
L’expérience Volumio
Volumio OS à bord. L’app en main.
Le Primo V3 fonctionne sous Volumio OS, le lecteur de plus de 800 000 appareils. Vous le pilotez depuis l’application Volumio, gratuite sur iPhone et Android.
Volumio OS à bord
Fonctions Premium intégrées
Toute votre musique. Une plateforme.
Le Primo V3 intègre toutes les fonctions Premium. TIDAL, Qobuz et Spotify côtoient des radios Internet comme Radio Paradise et TuneIn, au même endroit. TIDAL Connect, Qobuz Connect, Spotify Connect et AirPlay fonctionnent aussi.
Elles appartiennent à ce Primo, sans abonnement. Sur un Raspberry Pi ou un PC, les mêmes fonctions sont incluses dans un abonnement Volumio Premium.
Sur votre téléviseur
Branchez un câble HDMI et parcourez votre musique sur grand écran, jusqu’en 4K à 60 fps.
En main
Parcourez, écoutez et pilotez tout depuis l’application Volumio, sans perte et en haute résolution.
Comparer
Primo V3 ou Primo V2
Ce sont deux streamers DAC avec les fonctions Premium intégrées, et tous deux mesurent 27 × 15 × 5,2 cm. Le Primo V3 passe au DAC ES9039Q2M, lit jusqu’à PCM 384 kHz / 32-bit et ajoute des sorties réglables et le mode NOS. Le Primo V2 conserve une sortie S/PDIF coaxiale et existe en deux finitions.
Primo V3
Dernière génération
Acheter, Primo V3
Primo V2
Classic ou Florence Edition. iF Design Award 2024.
Acheter, Primo V2Découvrir le Primo V2
- DAC
- Primo V3 : ESS ES9039Q2M
- Primo V2 : ESS ES9038Q2M
- Résolution du DAC
- Primo V3 : Jusqu’à PCM 384 kHz / 32-bit
- Primo V2 : Jusqu’à PCM 192 kHz / 24-bit
- Filtres du DAC
- Primo V3 : 8, Minimum Phase par défaut
- Primo V2 : 7
- Mode NOS
- Primo V3 : Disponible
- Primo V2 : Non disponible
- Sortie XLR symétrique
- Primo V3 : 8 niveaux au choix, de 1,00 à 6,30 Vrms
- Primo V2 : 4 Vrms, fixe
- Sortie RCA asymétrique
- Primo V3 : 8 niveaux au choix, de 0,50 à 3,15 Vrms
- Primo V2 : 2 Vrms, fixe
- Sortie S/PDIF coaxiale
- Primo V3 : Non disponible
- Processeur
- Primo V3 : ARM Cortex-A72, quatre cœurs, 1,5 GHz
- Primo V2 : ARM Cortex-A55, quatre cœurs, 1,9 GHz
- Ports USB-A
- Primo V3 : 2 × USB 2.0, 0,56 A et 1,33 A
- Primo V2 : 1 × USB 3.0 et 1 × USB 2.0
- Sur les deux
- 2 Go de mémoire DDR4 et 16 Go de stockage eMMC. Gigabit Ethernet, Wi-Fi double bande et Bluetooth 5.0. HDMI jusqu’en 4K / 60 fps. Mode préamplificateur, directement vers un amplificateur de puissance. Alimentation 5 V / 3 A. 27 × 15 × 5,2 cm et 1,12 kg. Fonctions Premium intégrées.
Primo V3
Fiche technique
Caractéristiques audio du Primo V3
- DAC
- Filtres du DAC
- 8 filtres numériques pour affiner le son
- Résolution prise en charge
- Jusqu’à PCM 384 kHz / 32 bit
- Mode NOS
- Activable ou désactivable
- Horloge maître
- Bruit de phase ultra-faible
- Mode préamplificateur
- Matériel, volume réglé par l’application
- Alimentation
- Étage d’alimentation linéaire intégré
- Sortie USB
- Jusqu’à PCM 1536 kHz / 32 bit et DSD1024, multiroom désactivé
- Sortie analogique symétrique
- 1,00 ; 1,55 ; 2,00 ; 3,00 ; 4,00 ; 5,00 ; 6,00 ; 6,30 (Vrms)
- Sortie analogique asymétrique
- 0,50 ; 0,775 ; 1,00 ; 1,50 ; 2,00 ; 2,50 ; 3,00 ; 3,15 (Vrms)
- Impédance de sortie analogique
- ≈140 Ω
- Formats pris en charge
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 et autres
- Services pris en charge
- AirPlay via Shairport Sync, Spotify Connect, TIDAL et TIDAL Connect, Qobuz et Qobuz Connect, Roon
- UPnP/DLNA
- Renderer compatible OpenHome
- Plugins
Caractéristiques matérielles du Primo V3
- USB
- 2 × USB-A 2.0 (5 V / 0,56 A ; 5 V / 1,33 A)
- 1 × XLR (stéréo)
- 1 × RCA (stéréo)
- Sortie vidéo
- Recopie de l’application Volumio OS en HDMI, jusqu’en 4K / 60 fps
- LAN
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2,4 GHz et 5 GHz
- Bluetooth
- 5.0
- CPU
- ARM Cortex-A72, quatre cœurs, 1,5 GHz
- RAM
- 2 Go DDR4
- Stockage interne
- 16 Go eMMC
- Alimentation
- 5 V DC / 3 A
- Entrée d’alimentation
- Connecteur DC 5,5 × 2,1 mm (positif au centre)
- Dimensions
- Poids
- 1,12 kg (2,47 lb)
- Dimensions du colis
- Poids du colis
- 1,96 kg (4,32 lb)
Dans la boîte
- Volumio Primo V3
- Alimentation 5 V / 3 A
- Carte d’information NFC et QR code
Avis de propriétaires
L’avis des clients du Primo V3
Rédiger un avis sur la boutique
Avis d’acheteurs vérifiés sur shop.volumio.com, recueillis par REVIEWS.io. Affichés tels quels, dans la langue de leur auteur.
Lo más destacado
- Volumio OSintegrado: TIDAL, Qobuz, Spotify Connect, AirPlay y Roon Ready, con todas las funciones Premium incluidas
- 384kHzPCM a 32-bit, desde el DAC integrado
- 8+ NOSfiltros del DAC, o ninguno
- 8nivelesde salida para adaptarse a tu amplificador, hasta 6,3 Vrms en balanceado
- Previopor hardware, con el volumen desde la app: conéctalo directamente a una etapa de potencia
- 4KVolumio en tu televisor por HDMI, a 60 fps
Primo V3 está diseñado y fabricado en Florencia.
Hecho en Florencia
Ensamblado a mano, en Italia
Primo V3 se diseña en Florencia y se ensambla allí a mano, a cargo del mismo equipo que escribe su software. Cada unidad se revisa antes de salir del laboratorio.
Más sobre Volumio en FlorenciaPor dentro
Diseñado para el sonido
Primo V3 es un rediseño completo del Primo original. Una etapa de alimentación lineal y un reloj de alta precisión mantienen bajos el ruido y el jitter, y el diseño de la placa acorta todas las rutas de corriente. En el borde se esconde un guiño a Florencia. Elige un componente para localizarlo en la placa.
Sonido
Adáptalo a tu equipo
Ocho filtros, o ninguno
Elige uno de los ocho filtros del DAC, con Minimum Phase como predeterminado. O activa el modo NOS para una conversión sin sobremuestreo.
Ocho niveles de salida
Ajusta el nivel a tu amplificador o a tus altavoces activos. Con el volumen controlado desde la app, Primo V3 también funciona como preamplificador, conectado directamente a una etapa de potencia.
Conexiones
Entrada de red. Salida analógica.
Reproduce por streaming con Gigabit Ethernet o wifi de doble banda. Después envía la señal en balanceado o en no balanceado, o a un DAC USB.
Entradas
- Ethernet
- Wi-Fi
- 802.11a/b/g/n/ac, 2,4 y 5 GHz
- Alimentación
- 5 V DC / 3 A, con conector de barril de 5,5 × 2,1 mm
Salidas
- Analógica
- DAC integrado, hasta PCM 384 kHz / 32-bit
- Balanceada
- XLR, de 1,00 a 6,30 Vrms en 8 niveles
- No balanceada
- RCA, de 0,50 a 3,15 Vrms en 8 niveles
- USB-A × 2
- A un DAC USB, hasta PCM 1536 kHz / 32-bit y DSD1024, con el multiroom desactivado
- HDMI
- Duplica la app de Volumio en tu televisor, hasta 4K a 60 fps
La experiencia Volumio
Volumio OS dentro. La app en tu mano.
Primo V3 funciona con Volumio OS, el reproductor que mueve más de 800.000 dispositivos. Se controla desde la app de Volumio, gratuita para iPhone y Android.
Volumio OS integrado
Funciones Premium incluidas
Toda tu música. Una sola plataforma.
Primo V3 incluye todas las funciones Premium. TIDAL, Qobuz y Spotify conviven con radios por internet como Radio Paradise y TuneIn, en un solo lugar. TIDAL Connect, Qobuz Connect, Spotify Connect y AirPlay también funcionan.
Vienen con este Primo, sin suscripción. En una Raspberry Pi o un PC, las mismas funciones se incluyen en una suscripción a Volumio Premium.
En tu televisor
Conecta el HDMI y explora tu música en la pantalla grande, hasta en 4K a 60 fps.
En tu mano
Explora, reproduce y contrólalo todo desde la app de Volumio, sin pérdidas y en alta resolución.
Comparativa
Primo V3 o Primo V2
Los dos son streamer DAC con las funciones Premium incluidas, y los dos miden 27 × 15 × 5,2 cm. Primo V3 pasa al DAC ES9039Q2M, reproduce hasta PCM 384 kHz / 32-bit y añade salidas ajustables y el modo NOS. Primo V2 conserva una salida S/PDIF coaxial y se ofrece en dos acabados.
Primo V3
Última generación
Comprar, Primo V3
Primo V2
Comprar, Primo V2Descubrir Primo V2
- DAC
- Resolución del DAC
- Primo V3: Hasta PCM 384 kHz / 32-bit
- Primo V2: Hasta PCM 192 kHz / 24-bit
- Filtros del DAC
- Primo V3: 8, Minimum Phase como predeterminado
- Primo V2: 7
- Modo NOS
- Primo V3: Disponible
- Primo V2: No disponible
- Salida XLR balanceada
- Primo V3: 8 niveles seleccionables, de 1,00 a 6,30 Vrms
- Primo V2: 4 Vrms, fija
- Salida RCA no balanceada
- Primo V3: 8 niveles seleccionables, de 0,50 a 3,15 Vrms
- Primo V2: 2 Vrms, fija
- Salida S/PDIF coaxial
- Primo V3: No disponible
- Procesador
- Primo V3: ARM Cortex-A72, cuatro núcleos, 1,5 GHz
- Primo V2: ARM Cortex-A55, cuatro núcleos, 1,9 GHz
- Puertos USB-A
- Primo V3: 2 × USB 2.0, 0,56 A y 1,33 A
- Primo V2: 1 × USB 3.0 y 1 × USB 2.0
- En ambos
- Memoria DDR4 de 2 GB y almacenamiento eMMC de 16 GB. Gigabit Ethernet, Wi-Fi de doble banda y Bluetooth 5.0. HDMI hasta 4K / 60 fps. Modo preamplificador, directo a una etapa de potencia. Alimentación de 5 V / 3 A. 27 × 15 × 5,2 cm y 1,12 kg. Funciones Premium incluidas.
Primo V3
Especificaciones
Especificaciones de audio de Primo V3
- DAC
- Filtros del DAC
- 8 filtros digitales para el ajuste fino
- Resolución admitida
- Hasta PCM 384 kHz / 32 bit
- Modo NOS
- Activable (ON/OFF)
- Reloj maestro
- Ruido de fase ultrabajo
- Modo preamplificador
- Por hardware, volumen desde la app
- Fuente de alimentación
- Etapa de alimentación lineal integrada
- Salida USB
- Hasta PCM 1536 kHz / 32 bit y DSD1024, con el multiroom desactivado
- Salida analógica balanceada
- Salida analógica no balanceada
- Impedancia de salida analógica
- ≈140 Ω
- Formatos admitidos
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 y otros
- Servicios compatibles
- AirPlay mediante Shairport Sync, Spotify Connect, TIDAL y TIDAL Connect, Qobuz y Qobuz Connect, Roon
- UPnP/DLNA
- Renderizador compatible con OpenHome
- Plugins
Especificaciones de hardware de Primo V3
- USB
- 1 × XLR (estéreo)
- 1 × RCA (estéreo)
- Salida de vídeo
- Duplicado de la app de Volumio OS por HDMI hasta 4K / 60 fps
- LAN
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2,4 GHz y 5 GHz
- Bluetooth
- 5.0
- CPU
- ARM Cortex-A72, cuatro núcleos a 1,5 GHz
- RAM
- 2 GB DDR4
- Almacenamiento interno
- 16 GB eMMC
- Alimentación
- 5 V DC / 3 A
- Entrada de alimentación
- Conector de barril de 5,5 × 2,1 mm (polaridad positiva)
- Dimensiones
- Peso
- 1,12 kg (2,47 lb)
- Dimensiones del paquete
- Peso del paquete
- 1,96 kg (4,32 lb)
En la caja
- Volumio Primo V3
- Fuente de alimentación de 5 V / 3 A
- Tarjeta informativa con NFC y código QR
Reseñas de propietarios
Qué opinan de Primo V3
Escribir una reseña en la tienda
Reseñas de compradores verificados en shop.volumio.com, recopiladas por REVIEWS.io. Se muestran tal como se escribieron, en el idioma de cada autor.
Reviews
Lineo5 Duo
AU$857.80 -
Remoto
AU$69.00 -
Primo Plus
Was: AU$2,499.00Now: AU$1,679.00 -
Preciso
Was: AU$1,399.00Now: AU$1,119.00 -
Rivo Plus
AU$2,375.87 -
Lineo5
AU$849.00 -
Motivo
AU$3,199.00 -
Integro
AU$1,499.00 -
Primo
Was: AU$1,399.00Now: AU$1,039.00
