Rivo Plus
€1 299,00
Adding to cart… The item has been added
Selected Color is
The Rivo Plus builds on the acclaimed Rivo model, now featuring a dedicated ASIC for enhanced S/PDIF and AES-EBU outputs and upgraded MEMS clocks in the USB HUB IC. This delivers pure digital sound and seamless connectivity for audiophiles.
Includes all Volumio Premium features
Important Notice:
The Lineo 5 is not available for sale in the United States due to customs and regulatory restrictions.
All orders placed from the US will be refunded.
The price includes shipping, import duties and sales taxes.
Made in Florence Made in Florence
Free Delivery Free Delivery
30 Day Returns 30 Day Returns
OPTIMIZED CLOCK STABILITY
Upgraded MEMS clocks in the USB HUB IC enhance reclocking and signal integrity at the USB DAC port, ensuring superior jitter stability and consistent audio quality
I2S/DSD OVER HDMI CONNECTIVITY ADDED
I2S/DSD over HDMI interface offers optimal sonic performance for some external DACs compared to S/PDIF, AES-EBU, and USB
DEDICATED SUPPORT
One-on-one support to help with everything from set-up to troubleshooting. Always available for you!
THE ULTIMATE DIGITAL TRANSPORT
The Rivo+ is the enhanced version of our award-winning Rivo digital transport. Engineered based on user feedback, Rivo+ elevates the already excellent qualities of the original.
Key upgrades include a dedicated ASIC for cleaner S/PDIF and AES-EBU outputs, improved MEMS clocks for lower jitter, I2S over HDMI connectivity for compatible high-end DACs, and a 12V trigger to power on/off other components.
If you demand the pinnacle of digital transport performance, the Rivo+ is the solution.
ENHANCED AUDIO VIA I2S/DSD OVER HDMI FOR DISCERNING LISTENERS
The Rivo+ features a dedicated ASIC to generate the S/PDIF and AES-EBU output signals, offloading this crucial task from the CPU. This specialized integrated circuit is designed to produce these digital output signals with uncompromising precision, free from any potential interference or jitter introduced by the main processor.
Powering this dedicated ASIC is a high-quality MEMS (Micro-Electro-Mechanical Systems) clock, which provides an exceptionally stable and low-jitter timing reference. Coupled with low-noise voltage regulators, this enhancement to the RIVO+ ensures the output signals maintain the utmost purity and refinement.
ENJOY MUSIC FROM YOUR FAVORITE SOURCES
Rivo+ lets you stream from your favorite music services
Bring your content from local or network-attached drives and play internet radio
streaming-services-qobuz-spotify
ENGINEERED FOR SIGNAL PRECISION
Upgraded MEMS clocks in the USB HUB IC enhance reclocking and signal integrity for Rivo+ especially when connected to the USB DAC port. This delivers exceptional jitter and frequency stability, reducing susceptibility to temperature changes and aging for consistently high-quality audio output.
EASY SETUP
Getting started just takes a couple of minutes with the Volumio official iOS and Android apps
MADE IN ITALY
All Volumio products are proudly designed and assembled in Florence Italy
ROON READY
All Volumio products are Roon Ready certified by Roon Labs. allowing seamless integration with Roon
MULTIPLE CONNECTIVITY OPTIONS TO EXPLORE
S/PDIF and AES-EBU outputs generated by a dedicated ASIC with low-noise power supply + I2S/DSD over HDMI interface for optimized connection and enhanced audio performance.
VOLUMIO PREMIUM BUILT IN
On board, the Rivo+ is the latest version of Volumio – Volumio AI- that incorporates Supersearch an AI-powered search function that is meant to optimize your music discovery.
Volumio OS comes with a Multi-room capability that creates an integrated environment with other Volumio stations in your home.
INCLUDED IN THE BOX
  • Volumio Rivo+
  • NFC Information Card
  • 5V, 3A Power Supply
Audio
Digital Coaxial S/PDIF
Audio Output, up to PCM 192kHz/24bit and DSD64 via DoP
Digital AES/EBU
Audio Output, up to to PCM 192kHz/24bit and DSD64 via DoP
Digital I2S over HDMI Output
Audio Output, up to PCM 768kHz/32bit and DSD256
USB Output
Audio Output, up to PCM 768kHz/32bit and DSD256 (via USB DAC)
Power & Connectivity
USB DAC Port
1x USB 2.0
USB
1x USB 3.0, 1x USB 2.0
LAN
Gigabit 10/100/1000M
Wireless
Wi-Fi 802.11a/b/g/n/ac, 2X2 MIMO with RSDB
Bluetooth
5.0
Additional Info
Supported Formats
DSD, WAV, FLAC, Alac, Aac, Vorbis, Mp3 and others
UPNP DLNA
Renderer with Open Home support
Supported Services
Airplay via Shairport Sync, Spotify & Spotify Connect, TIDAL & TIDAL Connect, QOBUZ
Available Plugins
Youtube, Squeezelite, Radio Paradise, Podcasts, Pandora, Fusion DSP, Roon Bridge, Soundcloud, Mixcloud
CPU
Amlogic S905D3, Quad Core 1.9 GHz
RAM
2 GB DDR4
Internal Storage
16 GB EMMC
Power Supply
5V, 3A
Design
Designer
Design Narratives Ltd.
Weight
2.25 kg
Dimensions
27x15x5 cm
User Manual
Download Volumio Rivo+ User Manual Below:
Volumio Rivo+ Quick Start Guide Below:
Reviews
