The highlights
- Volumio OSinside, Volumio Premium built in. Works with TIDAL, Qobuz, Spotify Connect, AirPlay and Roon Ready (subscriptions sold separately)
- 1536kHzPCM at 32-bit and DSD1024 over USB, with multiroom off
- 768kHzPCM at 32-bit and up to DSD512, on the I2S over HDMI output
- 192kHzPCM at 24-bit and DSD64 via DoP, on S/PDIF coaxial and AES/EBU
- 4digital outputs: USB, I2S over HDMI, AES/EBU and S/PDIF coaxial
- 12Vtrigger output, to switch your other components on and off
Rivo Plus is designed and assembled in Florence, like every Volumio product.
Made in Florence
Assembled by hand, in Italy
Rivo Plus is designed in Florence and assembled there by hand, by the team that also writes its software. Each unit is checked before it leaves the lab.
More about Volumio in FlorenceLook inside
Cleaner outputs. Steadier clocks.
Rivo Plus is the enhanced version of Rivo, engineered from what listeners asked for. A dedicated ASIC now generates the S/PDIF coaxial and AES/EBU signals, and improved MEMS clocks lower jitter.
A dedicated ASIC
An ASIC is a chip built for one task. Here it generates the S/PDIF coaxial and AES/EBU output signals. This takes the job off the main processor, so its interference and jitter stay out of these outputs.
A MEMS clock and quiet power
A high-quality MEMS (micro-electro-mechanical systems) clock drives the ASIC and gives it a very stable, low-jitter timing reference. Low-noise voltage regulators power it.
Reclocked USB
An upgraded MEMS clock in the USB hub chip improves reclocking and signal integrity, above all on the USB DAC output. It keeps jitter low and the frequency stable, with less drift from temperature changes and aging.
Outputs
Four ways to your DAC
Rivo Plus is a digital transport. It sends the signal to your DAC through USB, I2S over HDMI, AES/EBU or S/PDIF coaxial. A 12 V trigger switches your other components on and off.
USB
1536kHz
Up to PCM 1536 kHz / 32-bit and DSD1024, with multiroom off. The USB-A 2.0 output has power filtering, and an upgraded MEMS clock in the USB hub chip improves its reclocking.
I2S over HDMI
768kHz
Up to PCM 768 kHz / 32-bit and DSD512, with multiroom off. For compatible DACs. The pinout routing of the HDMI connector is adjustable.
192kHz
Up to PCM 192 kHz / 24-bit and DSD64 via DoP, on both. The dedicated ASIC generates both signals, with its own MEMS clock and a low-noise power supply.
Trigger
12V
A trigger output on a 3.5 mm jack, positive on tip. It switches your other components on and off.
Connections
From your network to your DAC
Stream over Gigabit Ethernet or dual-band Wi-Fi, or play from a USB drive. On the back, I2S and video each have their own HDMI connector.
In
- Ethernet
- Gigabit, 10/100/1000
- Wi-Fi
- 802.11a/b/g/n/ac, 2.4 and 5 GHz
- USB-A × 2
- Flash drives, HDD and SSD, on one USB 2.0 and one USB 3.0 port
- Power
- 5 V DC / 3 A, on a 5.5 × 2.1 mm barrel jack
Out
- USB DAC
- USB-A 2.0 with power filtering
- I2S
- HDMI connector with adjustable pinout routing
- AES/EBU
- XLR connector, fed by the dedicated ASIC
- S/PDIF coaxial
- RCA connector, fed by the dedicated ASIC
- HDMI
- Mirrors the Volumio app on your TV, up to 4K at 60 fps
- Trigger
- 12 V on a 3.5 mm jack, positive on tip
The Volumio experience
Rivo Plus runs Volumio OS, the player behind 800,000+ devices. You play it from the Volumio app, free on iPhone and Android.
Volumio OS inside
Premium features built in
Your music, all in one place
Volumio Premium built in. Stream with your TIDAL, Qobuz or Spotify account, plus their Connect features and AirPlay. Play local or network drives, or internet radio.
The Premium features belong to this Rivo Plus, with no subscription. On a Raspberry Pi or a PC, the same features come with a Volumio Premium subscription.
On your TV
Connect HDMI and browse your music on the big screen, in up to 4K at 60 fps.
In your hand
Getting started takes a couple of minutes with the Volumio app for iOS and Android.
Supersearch
An AI-powered search that helps you discover music.
Multiroom
Links Rivo Plus with the other Volumio players in your home.
Roon Ready
Certified by Roon Labs, so Rivo Plus works with Roon.
Finishes
Classic or Special Edition
Rivo Plus comes in two finishes. The Special Edition has a refined brown leather finish, inspired by Italian craftsmanship.
Classic
A deep blue front with a square button, in a grey case.
Special Edition
Brown leather on the front, and a diamond-stitched leather top.
Compare
Rivo Plus or Rivo
Both are streamer transports with the Premium features built in, the same processor and the same USB DAC output, and both measure 27 × 15 × 5.2 cm. Rivo Plus adds a dedicated ASIC for the S/PDIF coaxial and AES/EBU outputs, upgraded MEMS clocks, I2S over HDMI and a 12 V trigger.
Rivo Plus
The enhanced Rivo
Buy, Rivo Plus
Rivo
EISA Best Digital Player 2023–2024
Buy, Rivo
- S/PDIF coaxial and AES/EBU outputs
- Rivo Plus: Up to PCM 192 kHz / 24-bit and DSD64 via DoP
- Rivo: Up to PCM 192 kHz / 24-bit
- Dedicated output ASIC
- Rivo Plus: Yes, for S/PDIF coaxial and AES/EBU, with its own MEMS clock
- Rivo: Not available
- USB clock
- Rivo Plus: Upgraded MEMS clock in the USB hub chip
- Rivo: Standard clock in the USB hub chip
- I2S over HDMI output
- Rivo Plus: Up to PCM 768 kHz / 32-bit and DSD512
- 12 V trigger output
- Rivo Plus: Yes, on a 3.5 mm jack
- Finishes
- Rivo Plus: Classic, or the Special Edition in brown leather
- Rivo: Classic, or the limited Black Edition in black upcycled leather
- On both
- USB DAC output up to PCM 1536 kHz / 32-bit and DSD1024, with multiroom off. ARM Cortex-A55 quad-core processor at 1.9 GHz, 2 GB DDR4 and 16 GB eMMC. Gigabit Ethernet, dual-band Wi-Fi and Bluetooth 5.0. HDMI up to 4K / 60 fps. 5 V / 3 A power. 27 × 15 × 5.2 cm and 1.12 kg. Premium features built in.
means not available on that model.
Rivo Plus
Tech specs
Audio specifications
- USB output
- Up to PCM 1536 kHz / 32 bit and DSD1024, with multiroom off
- Up to PCM 768 kHz / 32 bit and DSD512, with multiroom off
- S/PDIF coaxial output
- Up to PCM 192 kHz / 24 bit and DSD64 via DoP
- AES/EBU output
- Supported formats
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 and others
- Supported services
- AirPlay via Shairport Sync, Spotify Connect, TIDAL and TIDAL Connect, Qobuz and Qobuz Connect, Roon
- UPnP/DLNA
- Renderer with OpenHome support
- Plugins
- YouTube, Squeezelite, Radio Paradise, Podcasts, Pandora, Fusion DSP, SoundCloud, Mixcloud
Hardware specifications
- USB DAC output
- 1 × USB-A 2.0 with power filtering and signal-integrity reconstruction
- USB host
- 1 × USB-A 2.0, 1 × USB-A 3.0 (USB Flash Drive and HDD/SSD)
- I2S output
- 1 × HDMI with adjustable pinout routing
- Video output
- Volumio OS app mirroring over HDMI up to 4K / 60 fps
- Trigger out
- 1 × 3.5 mm jack (12 V, positive on tip)
- LAN
- Gigabit 10/100/1000 Mbps
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2.4 GHz and 5 GHz
- Bluetooth
- 5.0
- CPU
- ARM Cortex-A55, Quad Core 1.9 GHz
- RAM
- 2 GB DDR4
- Internal storage
- 16 GB eMMC
- Power
- 5 V DC / 3 A
- Power input
- Barrel jack 5.5 × 2.1 mm (positive polarity)
- Finishes
- Classic, or the Special Edition in brown leather
- Dimensions
- 27 × 15 × 5.2 cm (10.6 × 5.9 × 2.0 in)
- Weight
- 1.12 kg (2.47 lb)
- Box dimensions
- 31.5 × 19.7 × 11.6 cm (12.4 × 7.8 × 4.6 in)
- Box weight
- 1.96 kg (4.32 lb)
In the box
- Volumio Rivo Plus
- 5 V / 3 A power supply
- NFC and QR code information card
Owner reviews
What Rivo Plus owners say
Die Highlights
- Volumio OSan Bord, Volumio Premium integriert. Funktioniert mit TIDAL, Qobuz, Spotify Connect, AirPlay und Roon Ready (Abos separat erhältlich)
- 1536kHzPCM mit 32 Bit und DSD1024 über USB, bei deaktiviertem Multiroom
- 768kHzPCM mit 32 Bit und bis zu DSD512, am I2S-Ausgang (HDMI)
- 192kHzPCM mit 24 Bit und DSD64 über DoP, an S/PDIF koaxial und AES/EBU
- 4digitale Ausgänge: USB, I2S über HDMI, AES/EBU und S/PDIF koaxial
- 12VTrigger-Ausgang, um Ihre anderen Komponenten ein- und auszuschalten
Rivo Plus wird in Florenz entworfen und montiert, wie jedes Volumio-Produkt.
Hergestellt in Florenz
Von Hand montiert, in Italien
Rivo Plus wird in Florenz entworfen und dort von Hand montiert, von demselben Team, das auch seine Software schreibt. Jedes Gerät wird geprüft, bevor es das Labor verlässt.
Mehr über Volumio in FlorenzEin Blick ins Innere
Saubere Ausgänge. Stabile Taktgeber.
Rivo Plus ist die erweiterte Version von Rivo, entwickelt nach den Wünschen der Hörer. Ein dedizierter ASIC erzeugt jetzt die Signale für S/PDIF koaxial und AES/EBU, und verbesserte MEMS-Taktgeber senken den Jitter.
Ein ASIC ist ein Chip, der für eine einzige Aufgabe gebaut ist. Hier erzeugt er die Ausgangssignale für S/PDIF koaxial und AES/EBU. Das entlastet den Hauptprozessor, sodass dessen Störungen und Jitter von diesen Ausgängen fernbleiben.
MEMS-Takt, sauberer Strom
Ein hochwertiger MEMS-Taktgeber (mikroelektromechanische Systeme) steuert den ASIC und gibt ihm eine sehr stabile Zeitreferenz mit geringem Jitter. Rauscharme Spannungsregler versorgen ihn.
USB mit Reclocking
Ein verbesserter MEMS-Taktgeber im USB-Hub-Chip verbessert Reclocking und Signalintegrität, vor allem am USB-DAC-Ausgang. Er hält den Jitter gering und die Frequenz stabil, mit weniger Drift durch Temperaturschwankungen und Alterung.
Ausgänge
Vier Wege zu Ihrem DAC
Rivo Plus ist ein Streaming-Transport. Er schickt das Signal über USB, I2S über HDMI, AES/EBU oder S/PDIF koaxial an Ihren DAC. Ein 12-V-Trigger schaltet Ihre anderen Komponenten ein und aus.
USB
1536kHz
Bis zu PCM 1536 kHz / 32 Bit und DSD1024, bei deaktiviertem Multiroom. Der USB-A-2.0-Ausgang hat eine Stromfilterung, und ein verbesserter MEMS-Taktgeber im USB-Hub-Chip verbessert sein Reclocking.
I2S über HDMI
768kHz
Bis zu PCM 768 kHz / 32 Bit und DSD512, bei deaktiviertem Multiroom. Für kompatible DACs. Die Pinbelegung des HDMI-Anschlusses ist anpassbar.
192kHz
Bis zu PCM 192 kHz / 24 Bit und DSD64 über DoP, an beiden. Der dedizierte ASIC erzeugt beide Signale, mit eigenem MEMS-Taktgeber und rauscharmer Stromversorgung.
Trigger
12V
Ein Trigger-Ausgang über 3,5-mm-Klinke, Spitze positiv. Er schaltet Ihre anderen Komponenten ein und aus.
Anschlüsse
Von Ihrem Netzwerk zu Ihrem DAC
Streamen Sie über Gigabit-Ethernet oder Dualband-WLAN, oder spielen Sie von einem USB-Laufwerk ab. Auf der Rückseite haben I2S und Video je einen eigenen HDMI-Anschluss.
Eingänge
- Ethernet
- WLAN
- 802.11a/b/g/n/ac, 2,4 und 5 GHz
- USB-A × 2
- USB-Sticks, HDD und SSD, an einem USB-2.0- und einem USB-3.0-Anschluss
- Stromversorgung
- 5 V DC / 3 A, über Hohlbuchse 5,5 × 2,1 mm
Ausgänge
- USB-DAC
- USB-A 2.0 mit Stromfilterung
- I2S
- HDMI-Anschluss mit anpassbarer Pinbelegung
- AES/EBU
- XLR-Anschluss, gespeist vom dedizierten ASIC
- S/PDIF koaxial
- RCA-Anschluss, gespeist vom dedizierten ASIC
- HDMI
- Spiegelt die Volumio-App auf Ihren Fernseher, bis zu 4K mit 60 fps
- Trigger
- 12 V über 3,5-mm-Klinke, Spitze positiv
Das Volumio-Erlebnis
Volumio OS an Bord. Die App in der Hand.
Rivo Plus läuft mit Volumio OS, dem Player hinter 800.000+ Geräten. Sie bedienen ihn mit der Volumio-App, kostenlos für iPhone und Android.
Volumio OS an Bord
Premium-Funktionen integriert
Ihre Musik, alles an einem Ort
Volumio Premium integriert. Streamen Sie mit Ihrem TIDAL-, Qobuz- oder Spotify-Konto, dazu deren Connect-Funktionen und AirPlay. Spielen Sie von lokalen oder Netzlaufwerken ab, oder hören Sie Internetradio.
Die Premium-Funktionen gehören zu diesem Rivo Plus, ohne Abo. Auf einem Raspberry Pi oder PC gibt es dieselben Funktionen mit einem Volumio Premium-Abo.
Auf Ihrem Fernseher
Schließen Sie HDMI an und durchstöbern Sie Ihre Musik auf dem großen Bildschirm, in bis zu 4K mit 60 fps.
In Ihrer Hand
Mit der Volumio-App für iOS und Android ist alles in wenigen Minuten eingerichtet.
Super-Suche
Eine KI-gestützte Suche, mit der Sie neue Musik entdecken.
Multiroom
Verbindet Rivo Plus mit den anderen Volumio-Playern in Ihrem Zuhause.
Roon Ready
Von Roon Labs zertifiziert: Rivo Plus funktioniert mit Roon.
Ausführungen
Classic oder Special Edition
Rivo Plus gibt es in zwei Ausführungen. Die Special Edition hat eine edle Oberfläche aus braunem Leder, inspiriert von italienischer Handwerkskunst.
Classic
Eine tiefblaue Front mit quadratischer Taste, in einem grauen Gehäuse.
Special Edition
Braunes Leder an der Front und ein rautengesteppter Lederdeckel.
Vergleichen
Rivo Plus oder Rivo
Beide sind Streamer-Transporte mit integrierten Premium-Funktionen, demselben Prozessor und demselben USB-DAC-Ausgang, und beide messen 27 × 15 × 5,2 cm. Rivo Plus bietet zusätzlich einen dedizierten ASIC für die Ausgänge S/PDIF koaxial und AES/EBU, verbesserte MEMS-Taktgeber, I2S über HDMI und einen 12-V-Trigger.
Rivo Plus
Der erweiterte Rivo
Kaufen, Rivo Plus
Rivo
Kaufen, Rivo
- Ausgänge S/PDIF koaxial und AES/EBU
- Rivo Plus: Bis zu PCM 192 kHz / 24 Bit und DSD64 über DoP
- Rivo: Bis zu PCM 192 kHz / 24 Bit
- Dedizierter Ausgangs-ASIC
- Rivo Plus: Ja, für S/PDIF koaxial und AES/EBU, mit eigenem MEMS-Taktgeber
- Rivo: Nicht verfügbar
- USB-Taktgeber
- Rivo Plus: Verbesserter MEMS-Taktgeber im USB-Hub-Chip
- Rivo: Standard-Taktgeber im USB-Hub-Chip
- I2S-Ausgang (HDMI)
- Rivo Plus: Bis zu PCM 768 kHz / 32 Bit und DSD512
- 12-V-Trigger-Ausgang
- Rivo Plus: Ja, über 3,5-mm-Klinke
- Ausführungen
- Rivo Plus: Classic oder die Special Edition in braunem Leder
- Rivo: Classic oder die limitierte Black Edition in schwarzem Upcycling-Leder
- Bei beiden
- USB-DAC-Ausgang bis zu PCM 1536 kHz / 32 Bit und DSD1024, bei deaktiviertem Multiroom. Quad-Core-Prozessor ARM Cortex-A55 mit 1,9 GHz, 2 GB DDR4 und 16 GB eMMC. Gigabit-Ethernet, Dualband-WLAN und Bluetooth 5.0. HDMI bis 4K / 60 fps. Stromversorgung 5 V / 3 A. 27 × 15 × 5,2 cm und 1,12 kg. Premium-Funktionen integriert.
bedeutet: bei diesem Modell nicht verfügbar.
Rivo Plus
Technische Daten
Audio-Spezifikationen
- USB-Ausgang
- Bis zu PCM 1536 kHz / 32 Bit und DSD1024, bei deaktiviertem Multiroom
- Bis zu PCM 768 kHz / 32 Bit und DSD512, bei deaktiviertem Multiroom
- Koaxialer S/PDIF-Ausgang
- Bis zu PCM 192 kHz / 24 Bit und DSD64 über DoP
- AES/EBU-Ausgang
- Unterstützte Formate
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 und weitere
- Unterstützte Dienste
- AirPlay über Shairport Sync, Spotify Connect, TIDAL und TIDAL Connect, Qobuz und Qobuz Connect, Roon
- UPnP/DLNA
- Renderer mit OpenHome-Unterstützung
- Plugins
Hardware-Spezifikationen
- USB-DAC-Ausgang
- 1 × USB-A 2.0 mit Stromfilterung und Rekonstruktion der Signalintegrität
- USB-Host
- 1 × USB-A 2.0, 1 × USB-A 3.0 (USB-Stick und HDD/SSD)
- I2S-Ausgang
- 1 × HDMI mit anpassbarer Pinbelegung
- Videoausgang
- Spiegelung der Volumio-App über HDMI, bis zu 4K / 60 fps
- Trigger-Ausgang
- 1 × 3,5-mm-Klinke (12 V, Spitze positiv)
- LAN
- WLAN
- WLAN 802.11a/b/g/n/ac, 2,4 GHz und 5 GHz
- Bluetooth
- 5.0
- CPU
- ARM Cortex-A55, Quad-Core 1,9 GHz
- RAM
- 2 GB DDR4
- Interner Speicher
- 16 GB eMMC
- Stromversorgung
- 5 V DC / 3 A
- Stromeingang
- Hohlbuchse 5,5 × 2,1 mm (Pluspol innen)
- Ausführungen
- Classic oder die Special Edition in braunem Leder
- Abmessungen
- 27 × 15 × 5,2 cm (10,6 × 5,9 × 2,0 in)
- Gewicht
- 1,12 kg (2,47 lb)
- Verpackungsmaße
- 31,5 × 19,7 × 11,6 cm (12,4 × 7,8 × 4,6 in)
- Versandgewicht
- 1,96 kg (4,32 lb)
Lieferumfang
- Volumio Rivo Plus
- Netzteil 5 V / 3 A
- Infokarte mit NFC und QR-Code
Kundenbewertungen
Was Besitzer von Rivo Plus sagen
Bewertungen verifizierter Käufer auf shop.volumio.com, gesammelt von REVIEWS.io. Unverändert wiedergegeben, in der Sprache der Verfasser.
In evidenza
- Volumio OSa bordo, Volumio Premium incluso. Compatibile con TIDAL, Qobuz, Spotify Connect, AirPlay e Roon Ready (abbonamenti venduti separatamente)
- 1536kHzPCM a 32-bit e DSD1024 via USB, con multiroom disattivato
- 768kHzPCM a 32-bit e fino a DSD512, sull'uscita I2S su HDMI
- 192kHzPCM a 24-bit e DSD64 via DoP, su S/PDIF coassiale e AES/EBU
- 4uscite digitali: USB, I2S su HDMI, AES/EBU e S/PDIF coassiale
- 12Vuscita trigger, per accendere e spegnere gli altri componenti
Rivo Plus è progettato e assemblato a Firenze, come ogni prodotto Volumio.
Realizzato a Firenze
Assemblato a mano, in Italia
Rivo Plus è progettato a Firenze e assemblato lì a mano, dallo stesso team che ne scrive il software. Ogni unità viene controllata prima di lasciare il laboratorio.
Scopri di più su Volumio a FirenzeUno sguardo all'interno
Uscite più pulite. Clock più stabili.
Rivo Plus è la versione potenziata di Rivo, nata da ciò che chiedevano gli ascoltatori. Ora un ASIC dedicato genera i segnali S/PDIF coassiale e AES/EBU, e clock MEMS migliorati riducono il jitter.
Un ASIC dedicato
Un ASIC è un chip progettato per un solo compito. Qui genera i segnali delle uscite S/PDIF coassiale e AES/EBU. Così il processore principale è sollevato da questo lavoro, e le sue interferenze e il suo jitter restano fuori da queste uscite.
Clock MEMS, corrente pulita
Un clock MEMS (sistemi micro-elettro-meccanici) di alta qualità pilota l'ASIC e gli fornisce un riferimento temporale molto stabile, a basso jitter. Lo alimentano regolatori di tensione a basso rumore.
USB con reclocking
Un clock MEMS migliorato nel chip dell'hub USB perfeziona il reclocking e l'integrità del segnale, soprattutto sull'uscita USB DAC. Mantiene basso il jitter e stabile la frequenza, con meno deriva dovuta agli sbalzi di temperatura e all'invecchiamento.
Uscite
Quattro vie verso il tuo DAC
Rivo Plus è un transport digitale. Invia il segnale al tuo DAC via USB, I2S su HDMI, AES/EBU o S/PDIF coassiale. Un trigger a 12 V accende e spegne gli altri componenti.
USB
1536kHz
Fino a PCM 1536 kHz / 32-bit e DSD1024, con multiroom disattivato. L'uscita USB-A 2.0 ha l'alimentazione filtrata, e un clock MEMS migliorato nel chip dell'hub USB ne perfeziona il reclocking.
I2S su HDMI
768kHz
Fino a PCM 768 kHz / 32-bit e DSD512, con multiroom disattivato. Per i DAC compatibili. L'assegnazione dei pin del connettore HDMI è regolabile.
192kHz
Fino a PCM 192 kHz / 24-bit e DSD64 via DoP, su entrambe. L'ASIC dedicato genera entrambi i segnali, con un proprio clock MEMS e un'alimentazione a basso rumore.
Trigger
12V
Un'uscita trigger su jack da 3,5 mm, positivo sulla punta. Accende e spegne gli altri componenti.
Connessioni
Dalla rete al tuo DAC
Ascolta in streaming via Gigabit Ethernet o Wi-Fi dual band, oppure da un'unità USB. Sul retro, I2S e video hanno ciascuno il proprio connettore HDMI.
Ingressi
- Ethernet
- Wi-Fi
- 802.11a/b/g/n/ac, 2,4 e 5 GHz
- USB-A × 2
- Chiavette USB, HDD e SSD, su una porta USB 2.0 e una USB 3.0
- Alimentazione
- 5 V DC / 3 A, su spinotto DC da 5,5 × 2,1 mm
Uscite
- USB DAC
- USB-A 2.0 con alimentazione filtrata
- I2S
- Connettore HDMI con assegnazione dei pin regolabile
- AES/EBU
- Connettore XLR, pilotato dall'ASIC dedicato
- S/PDIF coassiale
- Connettore RCA, pilotato dall'ASIC dedicato
- HDMI
- Mostra l'app Volumio sulla tua TV, fino a 4K a 60 fps
- Trigger
- 12 V su jack da 3,5 mm, positivo sulla punta
L'esperienza Volumio
Volumio OS a bordo. L'app nelle tue mani.
Rivo Plus usa Volumio OS, il lettore che fa suonare oltre 800.000 dispositivi. Lo controlli dall'app Volumio, gratuita per iPhone e Android.
Volumio OS a bordo
Funzioni Premium incluse
La tua musica, tutta in un unico posto
Volumio Premium incluso. Ascolta in streaming con il tuo account TIDAL, Qobuz o Spotify, più le loro funzioni Connect e AirPlay. Riproduci da unità locali o di rete, o ascolta la radio via internet.
Le funzioni Premium restano legate a questo Rivo Plus, senza abbonamento. Su un Raspberry Pi o un PC, le stesse funzioni richiedono un abbonamento a Volumio Premium.
Sulla tua TV
Collega l'HDMI e sfoglia la tua musica sul grande schermo, fino a 4K a 60 fps.
Nelle tue mani
Per iniziare bastano un paio di minuti con l'app Volumio per iOS e Android.
Super ricerca
Una ricerca basata sull'AI che ti aiuta a scoprire nuova musica.
Multiroom
Collega Rivo Plus agli altri lettori Volumio di casa.
Roon Ready
Certificato da Roon Labs: Rivo Plus funziona con Roon.
Finiture
Classic o Special Edition
Rivo Plus è disponibile in due finiture. La Special Edition ha un raffinato rivestimento in pelle marrone, ispirato all'artigianato italiano.
Classic
Frontale blu intenso con pulsante quadrato, in uno chassis grigio.
Special Edition
Pelle marrone sul frontale e coperchio in pelle trapuntata a rombi.
Confronta
Rivo Plus o Rivo
Entrambi sono streamer transport con le funzioni Premium incluse, lo stesso processore e la stessa uscita USB DAC, ed entrambi misurano 27 × 15 × 5,2 cm. Rivo Plus aggiunge un ASIC dedicato per le uscite S/PDIF coassiale e AES/EBU, clock MEMS migliorati, I2S su HDMI e un trigger a 12 V.
Rivo Plus
Il Rivo potenziato
Acquista, Rivo Plus
Rivo
Acquista, Rivo
- Uscite S/PDIF coassiale e AES/EBU
- Rivo Plus: Fino a PCM 192 kHz / 24-bit e DSD64 via DoP
- Rivo: Fino a PCM 192 kHz / 24-bit
- ASIC di uscita dedicato
- Rivo Plus: Sì, per S/PDIF coassiale e AES/EBU, con un proprio clock MEMS
- Rivo: Non disponibile
- Clock USB
- Rivo Plus: Clock MEMS migliorato nel chip dell'hub USB
- Rivo: Clock standard nel chip dell'hub USB
- Uscita I2S su HDMI
- Rivo Plus: Fino a PCM 768 kHz / 32-bit e DSD512
- Uscita trigger 12 V
- Rivo Plus: Sì, su jack da 3,5 mm
- Finiture
- Rivo Plus: Classic, o la Special Edition in pelle marrone
- Rivo: Classic, o la Black Edition in serie limitata, in pelle nera di recupero
- In comune
- Uscita USB DAC fino a PCM 1536 kHz / 32-bit e DSD1024, con multiroom disattivato. Processore ARM Cortex-A55 quad-core a 1,9 GHz, 2 GB di DDR4 e 16 GB di eMMC. Gigabit Ethernet, Wi-Fi dual band e Bluetooth 5.0. HDMI fino a 4K / 60 fps. Alimentazione 5 V / 3 A. 27 × 15 × 5,2 cm e 1,12 kg. Funzioni Premium incluse.
significa non disponibile su quel modello.
Rivo Plus
Specifiche
Specifiche audio
- Uscita USB
- Fino a PCM 1536 kHz / 32 bit e DSD1024, con multiroom disattivato
- Fino a PCM 768 kHz / 32 bit e DSD512, con multiroom disattivato
- Uscita S/PDIF coassiale
- Fino a PCM 192 kHz / 24 bit e DSD64 via DoP
- Uscita AES/EBU
- Formati supportati
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 e altri
- Servizi supportati
- AirPlay via Shairport Sync, Spotify Connect, TIDAL e TIDAL Connect, Qobuz e Qobuz Connect, Roon
- UPnP/DLNA
- Renderer con supporto OpenHome
- Plugin
- YouTube, Squeezelite, Radio Paradise, Podcast, Pandora, Fusion DSP, SoundCloud, Mixcloud
Specifiche hardware
- Uscita USB DAC
- 1 × USB-A 2.0 con alimentazione filtrata e ricostruzione dell'integrità del segnale
- USB host
- 1 × USB-A 2.0, 1 × USB-A 3.0 (chiavette USB e HDD/SSD)
- Uscita I2S
- 1 × HDMI con assegnazione dei pin regolabile
- Uscita video
- Mirroring dell'app Volumio OS via HDMI fino a 4K / 60 fps
- Uscita trigger
- 1 × jack da 3,5 mm (12 V, positivo sulla punta)
- LAN
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2,4 GHz e 5 GHz
- Bluetooth
- 5.0
- CPU
- ARM Cortex-A55, Quad Core 1,9 GHz
- RAM
- 2 GB DDR4
- Archiviazione interna
- 16 GB eMMC
- Alimentazione
- 5 V DC / 3 A
- Ingresso di alimentazione
- Spinotto DC 5,5 × 2,1 mm (positivo al centro)
- Finiture
- Classic, o la Special Edition in pelle marrone
- Dimensioni
- Peso
- 1,12 kg (2,47 lb)
- Dimensioni imballo
- Peso con imballo
- 1,96 kg (4,32 lb)
Nella confezione
- Volumio Rivo Plus
- Alimentatore 5 V / 3 A
- Scheda informativa con NFC e codice QR
Recensioni dei proprietari
Il parere di chi ha Rivo Plus
Scrivi una recensione nello shop
Recensioni di acquirenti verificati su shop.volumio.com, raccolte da REVIEWS.io. Mostrate così come sono state scritte, nella lingua dell'autore.
Les points forts
- Volumio OSà bord, Volumio Premium inclus. Compatible TIDAL, Qobuz, Spotify Connect, AirPlay et Roon Ready (abonnements vendus séparément)
- 1536kHzPCM en 32-bit et DSD1024 en USB, multiroom désactivé
- 768kHzPCM en 32-bit et jusqu’au DSD512, sur la sortie I2S sur HDMI
- 192kHzPCM en 24-bit et DSD64 via DoP, en S/PDIF coaxial et AES/EBU
- 4sorties numériques : USB, I2S sur HDMI, AES/EBU et S/PDIF coaxiale
- 12Ven sortie trigger, pour allumer et éteindre vos autres appareils
Le Rivo Plus est conçu et assemblé à Florence, comme tous les produits Volumio.
Fabriqué à Florence
Assemblé à la main, en Italie
Le Rivo Plus est conçu à Florence et y est assemblé à la main, par l’équipe qui développe aussi son logiciel. Chaque exemplaire est contrôlé avant de quitter l’atelier.
En savoir plus sur Volumio à FlorenceVue intérieure
Sorties propres. Horloges stables.
Le Rivo Plus est la version améliorée du Rivo, conçue à partir des demandes des auditeurs. Un ASIC dédié génère désormais les signaux S/PDIF coaxial et AES/EBU, et des horloges MEMS améliorées réduisent la gigue.
Un ASIC dédié
Un ASIC est une puce conçue pour une seule tâche. Ici, il génère les signaux de sortie S/PDIF coaxial et AES/EBU. Le processeur principal est ainsi déchargé de ce travail, et ses interférences et sa gigue restent à l’écart de ces sorties.
Horloge MEMS, courant propre
Une horloge MEMS (microsystème électromécanique) de haute qualité pilote l’ASIC et lui fournit une référence temporelle très stable, à faible gigue. Des régulateurs de tension à faible bruit l’alimentent.
USB resynchronisé
Une horloge MEMS améliorée dans la puce du hub USB optimise le reclocking et l’intégrité du signal, surtout sur la sortie DAC USB. Elle maintient une gigue faible et une fréquence stable, avec moins de dérive due aux variations de température et au vieillissement.
Sorties
Quatre chemins vers votre DAC
Le Rivo Plus est un transport numérique. Il envoie le signal à votre DAC en USB, en I2S sur HDMI, en AES/EBU ou en S/PDIF coaxial. Un trigger 12 V allume et éteint vos autres appareils.
USB
1536kHz
Jusqu’à PCM 1536 kHz / 32-bit et DSD1024, multiroom désactivé. La sortie USB-A 2.0 dispose d’un filtrage de l’alimentation, et une horloge MEMS améliorée dans la puce du hub USB optimise son reclocking.
I2S sur HDMI
768kHz
Jusqu’à PCM 768 kHz / 32-bit et DSD512, multiroom désactivé. Pour les DAC compatibles. Le brochage du connecteur HDMI est réglable.
192kHz
Jusqu’à PCM 192 kHz / 24-bit et DSD64 via DoP, sur les deux. L’ASIC dédié génère les deux signaux, avec sa propre horloge MEMS et une alimentation à faible bruit.
Trigger
12V
Une sortie trigger sur jack 3,5 mm, positif sur la pointe. Elle allume et éteint vos autres appareils.
Connectique
De votre réseau à votre DAC
Diffusez en Gigabit Ethernet ou en Wi-Fi double bande, ou lisez depuis un disque USB. À l’arrière, l’I2S et la vidéo ont chacun leur propre connecteur HDMI.
Entrées
- Ethernet
- Wi-Fi
- 802.11a/b/g/n/ac, 2,4 et 5 GHz
- USB-A × 2
- Clés USB, HDD et SSD, sur un port USB 2.0 et un port USB 3.0
- Alimentation
- 5 V DC / 3 A, sur connecteur DC 5,5 × 2,1 mm
Sorties
- DAC USB
- USB-A 2.0 avec filtrage de l’alimentation
- I2S
- Connecteur HDMI à brochage réglable
- AES/EBU
- Connecteur XLR, piloté par l’ASIC dédié
- S/PDIF coaxiale
- Connecteur RCA, piloté par l’ASIC dédié
- HDMI
- Recopie l’application Volumio sur votre téléviseur, jusqu’en 4K à 60 fps
- Trigger
- 12 V sur jack 3,5 mm, positif sur la pointe
L’expérience Volumio
Volumio OS à bord. L’app en main.
Le Rivo Plus fonctionne sous Volumio OS, le lecteur de plus de 800 000 appareils. Vous le pilotez depuis l’application Volumio, gratuite sur iPhone et Android.
Volumio OS à bord
Fonctions Premium intégrées
Votre musique, réunie en un seul endroit
Volumio Premium inclus. Écoutez avec votre compte TIDAL, Qobuz ou Spotify, plus leurs fonctions Connect et AirPlay. Lisez depuis des disques locaux ou réseau, ou écoutez la radio sur Internet.
Les fonctions Premium appartiennent à ce Rivo Plus, sans abonnement. Sur un Raspberry Pi ou un PC, les mêmes fonctions sont incluses dans un abonnement Volumio Premium.
Sur votre téléviseur
Branchez un câble HDMI et parcourez votre musique sur grand écran, jusqu’en 4K à 60 fps.
En main
La prise en main ne demande que quelques minutes avec l’application Volumio pour iOS et Android.
Super recherche
Une recherche par IA qui vous aide à découvrir de la musique.
Multiroom
Relie le Rivo Plus aux autres lecteurs Volumio de la maison.
Roon Ready
Certifié par Roon Labs : le Rivo Plus fonctionne avec Roon.
Finitions
Classic ou Special Edition
Le Rivo Plus existe en deux finitions. La Special Edition arbore une élégante finition en cuir marron, inspirée du savoir-faire italien.
Classic
Une façade bleu profond avec un bouton carré, dans un boîtier gris.
Special Edition
Du cuir marron en façade, et un dessus en cuir surpiqué en losanges.
Comparer
Rivo Plus ou Rivo
Ce sont deux streamers transport avec les fonctions Premium intégrées, le même processeur et la même sortie DAC USB, et tous deux mesurent 27 × 15 × 5,2 cm. Le Rivo Plus ajoute un ASIC dédié aux sorties S/PDIF coaxiale et AES/EBU, des horloges MEMS améliorées, l’I2S sur HDMI et un trigger 12 V.
Rivo Plus
Le Rivo amélioré
Acheter, Rivo Plus
Rivo
Acheter, Rivo
- Sorties S/PDIF coaxiale et AES/EBU
- Rivo Plus : Jusqu’à PCM 192 kHz / 24-bit et DSD64 via DoP
- Rivo : Jusqu’à PCM 192 kHz / 24-bit
- ASIC de sortie dédié
- Rivo Plus : Oui, pour le S/PDIF coaxial et l’AES/EBU, avec sa propre horloge MEMS
- Rivo : Non disponible
- Horloge USB
- Rivo Plus : Horloge MEMS améliorée dans la puce du hub USB
- Rivo : Horloge standard dans la puce du hub USB
- Sortie I2S sur HDMI
- Rivo Plus : Jusqu’à PCM 768 kHz / 32-bit et DSD512
- Sortie trigger 12 V
- Rivo Plus : Oui, sur jack 3,5 mm
- Finitions
- Rivo Plus : Classic, ou la Special Edition en cuir marron
- Rivo : Classic, ou la Black Edition limitée en cuir noir surcyclé
- Sur les deux
- Sortie DAC USB jusqu’à PCM 1536 kHz / 32-bit et DSD1024, multiroom désactivé. Processeur ARM Cortex-A55 quatre cœurs à 1,9 GHz, 2 Go de DDR4 et 16 Go d’eMMC. Gigabit Ethernet, Wi-Fi double bande et Bluetooth 5.0. HDMI jusqu’en 4K / 60 fps. Alimentation 5 V / 3 A. 27 × 15 × 5,2 cm et 1,12 kg. Fonctions Premium intégrées.
signifie : non disponible sur ce modèle.
Rivo Plus
Fiche technique
Caractéristiques audio
- Sortie USB
- Jusqu’à PCM 1536 kHz / 32 bit et DSD1024, multiroom désactivé
- Jusqu’à PCM 768 kHz / 32 bit et DSD512, multiroom désactivé
- Sortie S/PDIF coaxiale
- Jusqu’à PCM 192 kHz / 24 bit et DSD64 via DoP
- Sortie AES/EBU
- Formats pris en charge
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 et autres
- Services pris en charge
- AirPlay via Shairport Sync, Spotify Connect, TIDAL et TIDAL Connect, Qobuz et Qobuz Connect, Roon
- UPnP/DLNA
- Renderer compatible OpenHome
- Plugins
Caractéristiques matérielles
- Sortie DAC USB
- 1 × USB-A 2.0 avec filtrage de l’alimentation et reconstruction de l’intégrité du signal
- USB hôte
- 1 × USB-A 2.0, 1 × USB-A 3.0 (clé USB et HDD/SSD)
- Sortie I2S
- 1 × HDMI avec brochage configurable
- Sortie vidéo
- Recopie de l’application Volumio OS en HDMI, jusqu’en 4K / 60 fps
- Sortie trigger
- 1 × jack 3,5 mm (12 V, positif sur la pointe)
- LAN
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2,4 GHz et 5 GHz
- Bluetooth
- 5.0
- CPU
- ARM Cortex-A55, quatre cœurs, 1,9 GHz
- RAM
- 2 Go DDR4
- Stockage interne
- 16 Go eMMC
- Alimentation
- 5 V DC / 3 A
- Entrée d’alimentation
- Connecteur DC 5,5 × 2,1 mm (positif au centre)
- Finitions
- Classic, ou la Special Edition en cuir marron
- Dimensions
- Poids
- 1,12 kg (2,47 lb)
- Dimensions du colis
- Poids du colis
- 1,96 kg (4,32 lb)
Dans la boîte
- Volumio Rivo Plus
- Alimentation 5 V / 3 A
- Carte d’information NFC et QR code
Avis de propriétaires
L’avis des clients du Rivo Plus
Rédiger un avis sur la boutique
Avis d’acheteurs vérifiés sur shop.volumio.com, recueillis par REVIEWS.io. Affichés tels quels, dans la langue de leur auteur.
Lo más destacado
- Volumio OSintegrado, con Volumio Premium incluido. Compatible con TIDAL, Qobuz, Spotify Connect, AirPlay y Roon Ready (suscripciones a la venta por separado)
- 1536kHzPCM a 32-bit y DSD1024 por USB, con el multiroom desactivado
- 768kHzPCM a 32-bit y hasta DSD512, en la salida I2S por HDMI
- 192kHzPCM a 24-bit y DSD64 mediante DoP, en S/PDIF coaxial y AES/EBU
- 4salidas digitales: USB, I2S por HDMI, AES/EBU y S/PDIF coaxial
- 12Vde salida de trigger, para encender y apagar tus otros componentes
Rivo Plus está diseñado y ensamblado en Florencia, como todos los productos Volumio.
Hecho en Florencia
Ensamblado a mano, en Italia
Rivo Plus se diseña en Florencia y se ensambla allí a mano, a cargo del mismo equipo que escribe su software. Cada unidad se revisa antes de salir del laboratorio.
Más sobre Volumio en FlorenciaPor dentro
Salidas limpias. Relojes estables.
Rivo Plus es la versión mejorada de Rivo, desarrollada a partir de lo que pedían los oyentes. Un ASIC dedicado genera ahora las señales S/PDIF coaxial y AES/EBU, y unos relojes MEMS mejorados reducen el jitter.
Un ASIC dedicado
Un ASIC es un chip creado para una sola tarea. Aquí genera las señales de las salidas S/PDIF coaxial y AES/EBU. Así libera de ese trabajo al procesador principal, y sus interferencias y su jitter no llegan a estas salidas.
Reloj MEMS y alimentación limpia
Un reloj MEMS (sistemas microelectromecánicos) de alta calidad gobierna el ASIC y le da una referencia temporal muy estable y de bajo jitter. Lo alimentan reguladores de tensión de bajo ruido.
USB con reclocking
Un reloj MEMS mejorado en el chip del hub USB optimiza el reclocking y la integridad de la señal, sobre todo en la salida DAC USB. Mantiene bajo el jitter y estable la frecuencia, con menos deriva por los cambios de temperatura y el envejecimiento.
Salidas
Cuatro caminos hasta tu DAC
Rivo Plus es un transporte digital. Envía la señal a tu DAC por USB, I2S por HDMI, AES/EBU o S/PDIF coaxial. Un trigger de 12 V enciende y apaga tus otros componentes.
USB
1536kHz
Hasta PCM 1536 kHz / 32-bit y DSD1024, con el multiroom desactivado. La salida USB-A 2.0 tiene filtrado de alimentación, y un reloj MEMS mejorado en el chip del hub USB optimiza su reclocking.
I2S por HDMI
768kHz
Hasta PCM 768 kHz / 32-bit y DSD512, con el multiroom desactivado. Para DAC compatibles. La asignación de pines del conector HDMI es ajustable.
192kHz
Hasta PCM 192 kHz / 24-bit y DSD64 mediante DoP, en ambas. El ASIC dedicado genera las dos señales, con su propio reloj MEMS y una fuente de alimentación de bajo ruido.
Trigger
12V
Una salida de trigger en una toma de 3,5 mm, con el positivo en la punta. Enciende y apaga tus otros componentes.
Conexiones
De tu red a tu DAC
Reproduce por streaming con Gigabit Ethernet o wifi de doble banda, o desde una unidad USB. En la parte trasera, I2S y vídeo tienen cada uno su propio conector HDMI.
Entradas
- Ethernet
- Wi-Fi
- 802.11a/b/g/n/ac, 2,4 y 5 GHz
- USB-A × 2
- Memorias USB, HDD y SSD, en un puerto USB 2.0 y otro USB 3.0
- Alimentación
- 5 V DC / 3 A, con conector de barril de 5,5 × 2,1 mm
Salidas
- DAC USB
- USB-A 2.0 con filtrado de alimentación
- I2S
- Conector HDMI con asignación de pines ajustable
- AES/EBU
- Conector XLR, con señal del ASIC dedicado
- S/PDIF coaxial
- Conector RCA, con señal del ASIC dedicado
- HDMI
- Duplica la app de Volumio en tu televisor, hasta 4K a 60 fps
- Trigger
- 12 V en una toma de 3,5 mm, con el positivo en la punta
La experiencia Volumio
Volumio OS dentro. La app en tu mano.
Rivo Plus funciona con Volumio OS, el reproductor que mueve más de 800.000 dispositivos. Se controla desde la app de Volumio, gratuita para iPhone y Android.
Volumio OS integrado
Funciones Premium incluidas
Tu música, toda en un solo lugar
Volumio Premium incluido. Escucha con tu cuenta de TIDAL, Qobuz o Spotify, además de sus funciones Connect y AirPlay. Reproduce desde unidades locales o de red, o escucha la radio por internet.
Las funciones Premium vienen con este Rivo Plus, sin suscripción. En una Raspberry Pi o un PC, las mismas funciones se incluyen en una suscripción a Volumio Premium.
En tu televisor
Conecta el HDMI y explora tu música en la pantalla grande, hasta en 4K a 60 fps.
En tu mano
Ponerlo en marcha lleva un par de minutos con la app de Volumio para iOS y Android.
Súper búsqueda
Una búsqueda con IA que te ayuda a descubrir música.
Multiroom
Conecta Rivo Plus con los demás reproductores Volumio de tu casa.
Roon Ready
Certificado por Roon Labs, para que Rivo Plus funcione con Roon.
Acabados
Rivo Plus se ofrece en dos acabados. La Special Edition tiene un refinado acabado en piel marrón, inspirado en la tradición artesana italiana.
Classic
Un frontal azul intenso con un botón cuadrado, en una caja gris.
Special Edition
Piel marrón en el frontal y una cubierta de piel con pespunte de rombos.
Comparativa
Rivo Plus o Rivo
Los dos son streamer transport con las funciones Premium incluidas, el mismo procesador y la misma salida DAC USB, y los dos miden 27 × 15 × 5,2 cm. Rivo Plus añade un ASIC dedicado para las salidas S/PDIF coaxial y AES/EBU, relojes MEMS mejorados, I2S por HDMI y un trigger de 12 V.
Rivo Plus
El Rivo mejorado
Comprar, Rivo Plus
Rivo
Comprar, Rivo
- Salidas S/PDIF coaxial y AES/EBU
- Rivo Plus: Hasta PCM 192 kHz / 24-bit y DSD64 mediante DoP
- Rivo: Hasta PCM 192 kHz / 24-bit
- ASIC de salida dedicado
- Rivo Plus: Sí, para S/PDIF coaxial y AES/EBU, con su propio reloj MEMS
- Rivo: No disponible
- Reloj USB
- Rivo Plus: Reloj MEMS mejorado en el chip del hub USB
- Rivo: Reloj estándar en el chip del hub USB
- Salida I2S por HDMI
- Rivo Plus: Hasta PCM 768 kHz / 32-bit y DSD512
- Salida de trigger de 12 V
- Rivo Plus: Sí, en una toma de 3,5 mm
- Acabados
- Rivo Plus: Classic, o la Special Edition en piel marrón
- Rivo: Classic, o la Black Edition limitada en piel negra reciclada
- En ambos
- Salida DAC USB hasta PCM 1536 kHz / 32-bit y DSD1024, con el multiroom desactivado. Procesador ARM Cortex-A55 de cuatro núcleos a 1,9 GHz, 2 GB DDR4 y 16 GB eMMC. Gigabit Ethernet, Wi-Fi de doble banda y Bluetooth 5.0. HDMI hasta 4K / 60 fps. Alimentación de 5 V / 3 A. 27 × 15 × 5,2 cm y 1,12 kg. Funciones Premium incluidas.
significa que no está disponible en ese modelo.
Rivo Plus
Especificaciones
Especificaciones de audio
- Salida USB
- Hasta PCM 1536 kHz / 32 bit y DSD1024, con el multiroom desactivado
- Hasta PCM 768 kHz / 32 bit y DSD512, con el multiroom desactivado
- Salida S/PDIF coaxial
- Hasta PCM 192 kHz / 24 bit y DSD64 mediante DoP
- Salida AES/EBU
- Formatos admitidos
- DSD, WAV, FLAC, ALAC, AAC, Vorbis, MP3 y otros
- Servicios compatibles
- AirPlay mediante Shairport Sync, Spotify Connect, TIDAL y TIDAL Connect, Qobuz y Qobuz Connect, Roon
- UPnP/DLNA
- Renderizador compatible con OpenHome
- Plugins
Especificaciones de hardware
- Salida DAC USB
- 1 × USB-A 2.0 con filtrado de alimentación y reconstrucción de la integridad de la señal
- Host USB
- 1 × USB-A 2.0, 1 × USB-A 3.0 (memoria USB y HDD/SSD)
- Salida I2S
- 1 × HDMI con asignación de pines configurable
- Salida de vídeo
- Duplicado de la app de Volumio OS por HDMI hasta 4K / 60 fps
- Salida de trigger
- 1 × toma de 3,5 mm (12 V, positivo en la punta)
- LAN
- Wi-Fi
- Wi-Fi 802.11a/b/g/n/ac, 2,4 GHz y 5 GHz
- Bluetooth
- 5.0
- CPU
- ARM Cortex-A55, cuatro núcleos a 1,9 GHz
- RAM
- 2 GB DDR4
- Almacenamiento interno
- 16 GB eMMC
- Alimentación
- 5 V DC / 3 A
- Entrada de alimentación
- Conector de barril de 5,5 × 2,1 mm (polaridad positiva)
- Acabados
- Classic, o la Special Edition en piel marrón
- Dimensiones
- Peso
- 1,12 kg (2,47 lb)
- Dimensiones del paquete
- Peso del paquete
- 1,96 kg (4,32 lb)
En la caja
- Volumio Rivo Plus
- Fuente de alimentación de 5 V / 3 A
- Tarjeta informativa con NFC y código QR
Reseñas de propietarios
Qué opinan de Rivo Plus
Escribir una reseña en la tienda
Reseñas de compradores verificados en shop.volumio.com, recopiladas por REVIEWS.io. Se muestran tal como se escribieron, en el idioma de cada autor.
Reviews
Rivo Ultra
€3 999,00 -
Primo V3
€849,00 -
Lineo5 Duo
€469,00 -
Remoto
€39,00 -
Primo Plus
Was: €1 199,00Now: €1 049,00 -
Preciso
Was: €799,00Now: €699,00 -
Lineo5
€349,00 -
Motivo
€1 749,00 -
Integro
€1 199,00 -
Primo
Was: €799,00Now: €649,00
